2008 Dodge cummins waterpump #1563685
01/15/14 07:47 PM
01/15/14 07:47 PM
Salt Lake City
camastomcat Offline OP
Salt Lake City
So....you truck mechanics....what should it cost to replace the waterpump on a 2008 cummins? And do they typically go out at 90K?
Re: 2008 Dodge cummins waterpump [Re: camastomcat] #1563686
01/15/14 09:08 PM
01/15/14 09:08 PM
Kansas
cascius Offline
cascius  Offline
Kansas
If you're paying a shop to do it I would think no more than $300. Mitchell shows labor time at 1.5 hours. $90 water pump, $30 in Antifreeze, plus shop supplies and taxes.
Re: 2008 Dodge cummins waterpump [Re: cascius] #1563687
01/16/14 11:32 AM
01/16/14 11:32 AM
Indiana
EV2DEMON Offline
The Camaro Kid
EV2DEMON  Offline
The Camaro Kid
Indiana
Water pump failure is common on late model Cummins. The pump on my 2008 went out at 48,000 miles.
Easiest water pump change I've ever done, took less than an hour. Remove the drive belt and 2 bolts and it's off.
Re: 2008 Dodge cummins waterpump [Re: EV2DEMON] #1563688
01/16/14 02:45 PM
01/16/14 02:45 PM
Guitar Jones Offline
Changing the pump is easy but the pumps are not cheap, like $300 just for the pump.
Re: 2008 Dodge cummins waterpump [Re: Guitar Jones] #1563689
01/17/14 11:15 AM
01/17/14 11:15 AM
Stinnett, Tx
rumblebee4232 Offline
Stinnett, Tx
I dont know where you are finding the $300.00 water pumps but if that is truely what you are paying I will sell them to you for $200.00 so you save a hundred.. NAPA, Oreillys, and Autozone all have them for $90.00.
Re: 2008 Dodge cummins waterpump [Re: rumblebee4232] #1563690
01/17/14 12:32 PM
01/17/14 12:32 PM
Dodge dealers list price for a new one. I could be wrong but I thought they were about that last time I checked.
Re: 2008 Dodge cummins waterpump [Re: camastomcat] #1563691
01/18/14 05:02 PM
01/18/14 05:02 PM
Buford, GA
I_bleed_MOPAR Offline
Buford, GA
Mine went out at 88k. Very easy to swap it out. Now the drive belt is another story...
Tim
'71 Charger 383/727
'17 Challenger SXT (Wifeys car wink )
Re: 2008 Dodge cummins waterpump [Re: I_bleed_MOPAR] #1563692
01/21/14 08:37 PM
01/21/14 08:37 PM
ST clair shores MI
moretoys Offline
moretoys  Offline
ST clair shores MI
If you have a truck shop / cummins dealer near you, go there. It's the same pump as the dealer except much cheaper. easy to do, take longer to bled the system,get it up to temperature for the thermostat to open. Takes alot of coolant.
Re: 2008 Dodge cummins waterpump [Re: moretoys] #1563693
01/22/14 11:47 PM
01/22/14 11:47 PM
ID/MT
Cheeto Offline
Cheeto  Offline
ID/MT
^ This ^
Cheeto
It's not perfect.
It's not correct.
It's not yours!
Re: 2008 Dodge cummins waterpump [Re: moretoys] #1563694
01/23/14 01:13 AM
01/23/14 01:13 AM
Louisville, KY
E
E-Ticket Offline
E-Ticket  Offline
E
Louisville, KY
agreed.... I value my Cummins engine much more than to put an aftermarket rebuilt junk water pump on my motor so its either Mopar/Cummins (both the same) or nothing. ESPECIALLY thermostats..... I only use Cummins brand thermostats.
I work for a dealership and cannot tell you how many customers have tried to take the cheap way out and buy an aftermarket pump & or thermostat only to come to us and buy an OEM once their aftermarket junk has left them with a tow bill......
"Fat drunk and stupid is no way to go through life son......"
http://www.youtube.com/watch?v=bK-Dqj4fHmM
Re: 2008 Dodge cummins waterpump [Re: E-Ticket] #1563695
01/23/14 04:22 PM
01/23/14 04:22 PM
Indiana
EV2DEMON Offline
The Camaro Kid
EV2DEMON  Offline
The Camaro Kid
Indiana
The original water pump on my truck failed after 4 years and 48000 miles. How can an aftermarket part be any worse than that?
Re: 2008 Dodge cummins waterpump [Re: EV2DEMON] #1563696
01/24/14 10:38 AM
01/24/14 10:38 AM
Bridgeport, WV
Michael Offline
Michael  Offline
Bridgeport, WV
I work my '06 Cummins Dually 7 days a week.It has 404,000 miles with the OEM waterpump on it.I have never had the valve cover off and I change oil every 5,000 miles.I bought the truck used in 2010 with 21,000 miles on it.I run over 100,000 miles a year hotshotting to the oil and gas rigs.I was above Dubois, PA yesterday and will be in OH today...love my job!!
Re: 2008 Dodge cummins waterpump [Re: EV2DEMON] #1563697
01/24/14 09:06 PM
01/24/14 09:06 PM
Louisville, KY
E
E-Ticket Offline
E-Ticket  Offline
E
Louisville, KY
While there have been OEM pump failures....most all the ones I have seen or heard about typically started leaking and very few had the bearing expire. I experienced a leaking water pump on my 03 truck at approximately 60,000 miles but didn't know it was leaking until I turned the engine off. It barely leaked while running so that allowed me to keep going until I got home to change it. The bearing was fine....it was just the internal seal.
Cummins parts, as with most OEM parts that are made for the auto manufacturer's....have to hold a much tighter tolerance in the manufacturing process of the parts than do the "stock" aftermarket parts manufacturer's. I was in the manufacturing industry for a better part of 25 years and if you were to see what I have seen over the years...you would most likely never even consider a "stock" aftermarket part that the engine rely's on to function properly......
Re: 2008 Dodge cummins waterpump [Re: E-Ticket] #1563698
01/24/14 11:13 PM
01/24/14 11:13 PM
PORT ALBERNI , BC., CANADA
superwrench Offline
superwrench  Offline
....Listen to what this man is saying.....
