Coil location and life #1563663
01/15/14 07:35 PM
01/15/14 07:35 PM
Mount Airy, Maryland
scrag Offline OP
scrag  Offline OP
I was considering replacing my coil as it was damaged wear the coil wire attaches. Currently have a MSD Blaster coil which I have mounted on my six pack intake in the stock location. Car is a BH car with a 500 stroker. So it I replace it is it better to mount somewhere else or is it still OK where it is at? Which coil is recommended?
Re: Coil location and life [Re: scrag] #1563664
01/15/14 09:02 PM
01/15/14 09:02 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
i also have my blaster in the stock location for a 6pac (sideways) and it's been like that for 20 years give or take. i have heard bad things about the newer blaster 2 coils (red ones)leaking. my suggestion is to get the high vibration blaster which is essentially an epoxy coil. same power as the blaster 2 but no leaky! it will also fit in the stock 6pac location! a win win
Re: Coil location and life [Re: scrag] #1563665
01/15/14 09:07 PM
01/15/14 09:07 PM
IN
ahy Offline
ahy  Offline
IN
Most OE coils were more or less horizontal. I assume your is also.
Aftermarket coils recommend vertical mount to prevent oil leaks and failure. Many mount them in stock location and it works... but sometimes it doesn't and early failure occurs.
If the stock location works for you I'd suggest the epoxy potted Blaster. It is recommended for any orientation as there is no oil to leak.
Re: Coil location and life [Re: ahy] #1563666
01/15/14 09:26 PM
01/15/14 09:26 PM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
If it's an option, vertical with a canister type coil, and with any coil, the area with the least amount of heat is what I'd recommend.
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
Re: Coil location and life [Re: scrag] #1563667
01/16/14 02:21 AM
01/16/14 02:21 AM
Ma mounted the coil sideways for decades & got by with it, with it being said nowadays that sideways can possibly cause an early failure (if oil filled). So I guess vertical would be the proactive way to go if you are willing to fab or buy a bracket & if where you mount it it looks OK straight up
Re: Coil location and life [Re: RapidRobert] #1563668
01/16/14 02:48 AM
01/16/14 02:48 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
I mount my coils vertically on the inner fenderwell. Easy to get to and out of the way.
As for the newer MSD Blaster II coils, they are absolute junk. The terminals are soft and the threads strip easily. $45 down the tubes for me.
Re: Coil location and life [Re: GY3] #1563669
01/16/14 12:22 PM
01/16/14 12:22 PM
I have a new red blaster 2 & I'm unsure how old it is (been sitting on it for a long time) & is there any identifying features that would tell me if it is or is not one of the inferior ones?
Re: Coil location and life [Re: RapidRobert] #1563670
01/16/14 04:00 PM
01/16/14 04:00 PM
scrag Offline OP
scrag  Offline OP
Thanks!
Re: Coil location and life [Re: scrag] #1563671
01/16/14 04:04 PM
01/16/14 04:04 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I have a red Blaster 2 on my sixpack Charger. I peeled the MSD sticker off & painted black to look OEM. It's been on my car for like 15+ years without any trouble.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Coil location and life [Re: 6PKRTSE] #1563672
01/16/14 04:40 PM
01/16/14 04:40 PM
St. Charles, MO
wingman Offline
Uncreative Title
wingman  Offline
Uncreative Title
St. Charles, MO
Did exactly the same thing with mine. 12+ for me.
1969 Dodge Coronet Super Bee 383 A4
1970 Plymouth Road Runner 440 FC7 (sold)
