ok another dumb question #1563273
01/14/14 09:38 PM
01/14/14 09:38 PM
ky
headhunter Offline OP
ky
would this be a place I could run a electric gauge at? or would it just be a area for a race only deal. does the gauge need to be in a lowing water area in a street car?
Re: ok another dumb question [Re: headhunter] #1563274
01/14/14 09:43 PM
01/14/14 09:43 PM
ky
ky
Re: ok another dumb question [Re: headhunter] #1563275
01/14/14 09:44 PM
01/14/14 09:44 PM
ky
ky
Re: ok another dumb question [Re: headhunter] #1563276
01/14/14 09:57 PM
01/14/14 09:57 PM
sg66mopar Offline
sg66mopar  Offline
Isn't the water cooled off a whole bunch by the time it gets down there?
Re: ok another dumb question [Re: sg66mopar] #1563277
01/14/14 10:02 PM
01/14/14 10:02 PM
ky
ky
not sure
Re: ok another dumb question [Re: headhunter] #1563278
01/14/14 10:03 PM
01/14/14 10:03 PM
ky
ky
this is whats on the other side so its pulling the water down that way
Re: ok another dumb question [Re: headhunter] #1563279
01/14/14 10:03 PM
01/14/14 10:03 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Water temp gauge I take it. The answer is no. If you want engine temp, witch I think you do. You need it closer to the motor.
Drill and tap the water pump at a convenient location. You will get a Very delayed and Inaccurate reading where your showing it will be now.
Edit, just saw the pic of the pump, my answer is the same. The water in the rad will take the shortest Path across at its entry starting at its top entry point. At that lower corner in the petcock a temp sending unit wont ever see correct temps.
Re: ok another dumb question [Re: Sport440] #1563280
01/14/14 10:16 PM
01/14/14 10:16 PM
ky
ky
not eally wanting to drill on a 500 dollar water pump need to see about a fitting in the line or the block adapters which ever I get mayby
Re: ok another dumb question [Re: Sport440] #1563281
01/14/14 10:18 PM
01/14/14 10:18 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
Only if this is a second gauge where you would want to know how well your radiator is working.
Probably not what you had in mind. So No.
Re: ok another dumb question [Re: headhunter] #1563282
01/14/14 10:22 PM
01/14/14 10:22 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Get the temp at the engine OR at the top hose close
to the engine... the bottom hose is the suction side
of the pump... in other words its the inlet to the engine
EDIT
Even if you wanted to monitor the radiator temp that
would be a BAD place... its not in the flow and sitting
in a dead place
Re: ok another dumb question [Re: headhunter] #1563283
01/14/14 10:32 PM
01/14/14 10:32 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
I posted that before I saw your electric pump. I was meaning the WP housing on the block. Whats your water manifold setup like at the block, find a spot there or put in on the outlet side of it in a hose type connecter.
Re: ok another dumb question [Re: Sport440] #1563284
01/14/14 10:38 PM
01/14/14 10:38 PM
ky
ky
does anyone make a connector that can go inline on a an line type hose?
Re: ok another dumb question [Re: headhunter] #1563285
01/14/14 10:55 PM
01/14/14 10:55 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
I don't know, maybe. But if you did the fabrication of the water pump to the rad , you probably could.
Re: ok another dumb question [Re: headhunter] #1563286
01/14/14 11:00 PM
01/14/14 11:00 PM
MR_P_BODY Offline
MR_P_BODY  Offline
You would want a T connector with AN, AN and the third
being a female pipe connector
Re: ok another dumb question [Re: headhunter] #1563287
01/15/14 01:23 AM
01/15/14 01:23 AM
Las Vegas
Al_Alguire Online laugh2
Las Vegas
Great place if ya wanna know how well your chiller works
We used a separate sensor on the motor as I do with the B1.
Re: ok another dumb question [Re: headhunter] #1563288
01/15/14 01:29 AM
01/15/14 01:29 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
http://www.jegs.com/p/Earls/Earls-AN-T-Fittings/749392/10002/-1?itemPerPage=90&pno=1
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: ok another dumb question [Re: hemi-itis] #1563289
01/15/14 02:06 AM
01/15/14 02:06 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I really doubt he can use a AN on all 3 points of the T..
I would think the side fitting will need to be NPT
Re: ok another dumb question [Re: MR_P_BODY] #1563290
01/15/14 02:34 AM
01/15/14 02:34 AM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Stuff the pick up in a thermostat housing or someplace like this.......
http://www.jegs.com/i/Moroso/710/63420/10002/-1
Re: ok another dumb question [Re: tubtar] #1563291
01/15/14 03:01 AM
01/15/14 03:01 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Myself I would just drill and tap the thermostat
housing itself with either a 1/4 NPT or 3/8 NPT
which ever size is needed
Re: ok another dumb question [Re: MR_P_BODY] #1563292
01/15/14 03:11 AM
01/15/14 03:11 AM
hemi-itis Offline
hemi-itis  Offline
That;s the ticket!!
Re: ok another dumb question [Re: hemi-itis] #1563293
01/15/14 10:24 PM
01/15/14 10:24 PM
ky
ky
e be a place for a thermostat houseing
