Mixing ATF+4 with regular ATF? #1563226
01/14/14 06:14 PM
01/14/14 06:14 PM
Spahn Ranch
RMCHRGR Offline OP
RMCHRGR  Offline OP
Spahn Ranch
I know this gets beaten to death and there are many varying opinions on ATF+4 but I'm gonna ask anyway because after all I've read through, I don't have a clear answer. Maybe there ins't one?
I've read so many different things about using ATF+4 in older TFs that it can get confusing - shifts are not as hard, formulated for newer lockup transmissions, may cause leaks due to different additives/detergents forming acids, the world will end yada yada.
My trans is a 904/999, Turbo Action forward manual valve body, (No LBA), 5 disc drum, low gear set etc. Nothing fancy. I changed the pan this winter and used a new silicone gasket. I did not drain the converter. Unit looked clean, fluid was clean. Previous owner said he ran Dexron in it. It shifts pretty hard but relatively smoothly at WOT. It's good.
Here's the thing - I have a case of ATF+4 on my shelf. What happens if I add the ATF+4 to my trans? Will I blow it up or will I not notice anything? Will it cause leaks?
Please advise.
- Greg
'71 Duster
'72 Challenger
'17 Ram 1500
Re: Mixing ATF+4 with regular ATF? [Re: RMCHRGR] #1563227
01/14/14 06:23 PM
01/14/14 06:23 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I`ve always ran type-F till recently where Wally world only had ATF+4 so been running that w/about 10 passes at the track and a few hundred street miles and all seems fine and fluid looks/smells new............
Re: Mixing ATF+4 with regular ATF? [Re: Thumperdart] #1563228
01/14/14 08:17 PM
01/14/14 08:17 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
It will not hurt anything, can change shift feel because of the different friction modifiers that are it the +4.
Will not cause any leaks the 904/999 uses the same rubber and seals as the 500od unit.
That being said I personally wouldn't use it in a race application.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Mixing ATF+4 with regular ATF? [Re: dusturbd340W5] #1563229
01/14/14 09:13 PM
01/14/14 09:13 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
I run +4 in my car and have mixed with +3 many times
Re: Mixing ATF+4 with regular ATF? [Re: RMCHRGR] #1563230
01/15/14 12:15 AM
01/15/14 12:15 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Please advise.
- Greg
I haven't a clue, but I like your style.
Re: Mixing ATF+4 with regular ATF? [Re: jcc] #1563231
01/15/14 02:17 AM
01/15/14 02:17 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Thats all my brother and I ever use. We both worked at Dodge dealers most of our life and we both did auto trans work so we have a fair amount of ATF+4 laying around as we got a few spare qts on some warranty jobs. The trans in my sons Dart has only had the ATF+3 and 4 as its been in his Dart since 1996 and it never been out just serviced a few times in the car which was filter and fluid changes. Ron
Re: Mixing ATF+4 with regular ATF? [Re: 383man] #1563232
01/15/14 11:55 AM
01/15/14 11:55 AM
Guitar Jones Offline
I agree, it won't be a problem. Heck I use Hyundai SPF III in mine because I have so much of it.
Re: Mixing ATF+4 with regular ATF? [Re: Guitar Jones] #1563233
01/15/14 05:08 PM
01/15/14 05:08 PM
Spahn Ranch
RMCHRGR Offline OP
RMCHRGR  Offline OP
Spahn Ranch
Cool, thanks guys. Seems like it won't be an issue. Just wanted to be sure before I dump it in. Again, I didn't remove the unit to drain the converter.
yeah, I was a Chrysler and Hyundai tech myself, that's why I have the +4. I've used Hyundai fluid in other vehicles too.
'71 Duster
'72 Challenger
'17 Ram 1500
Re: Mixing ATF+4 with regular ATF? [Re: RMCHRGR] #1563234
01/15/14 05:44 PM
01/15/14 05:44 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
Goldman out of Allentown Pa. does my transmissions and told me that ATF+4 is the best for 727's and 904's.
You can run it all year long and your transmission fluid will look like new.Clutches and steels look mint too.
Re: Mixing ATF+4 with regular ATF? [Re: Sammy] #1563235
01/15/14 07:38 PM
01/15/14 07:38 PM
Kissimmee Fl.
Kissimmee Fl.
build the unit correctly and you can use any fluid all year and it will look like new.
