cam ID can you help ? #1563221
01/14/14 03:44 PM
01/14/14 03:44 PM
Ohio
rustytoolss Offline OP
Ohio
I've got a small block cam that's stamped 458230. With calipers the lift would be .450". As I remember its a hydraulic cam. Have forgotten the specs.
Any help would be great. Thanks
Re: cam ID can you help ? [Re: rustytoolss] #1563222
01/15/14 04:23 AM
01/15/14 04:23 AM
Ohio
Ohio
Anybody ????
Re: cam ID can you help ? [Re: rustytoolss] #1563223
01/17/14 03:31 PM
01/17/14 03:31 PM
Ohio
Ohio
Anyone ??
Re: cam ID can you help ? [Re: rustytoolss] #1563224
01/17/14 03:59 PM
01/17/14 03:59 PM
Daytona Beach, FL
cknight Offline
cknight  Offline
Daytona Beach, FL
Is there anything else stamped on the front or the rear? Regards, Chase
Re: cam ID can you help ? [Re: cknight] #1563225
01/17/14 09:51 PM
01/17/14 09:51 PM
Ohio
Ohio
The numbers 1136 are CAST into the cam, on the rear stamped 458230. The guy I got it from said it was not enough cam for his 340/360 duster. I did a rough caliper check, comes out at .300 lift= .450" valve lift. I/E look to be the same. I've got a 273 with flat tops, if I knew more about this cam, might use it. Looking for lowend TQ and mileage.
