Re: engine floaded with gas
[Re: fc7_plumcrazy]
#1563058
01/14/14 01:44 PM
01/14/14 01:44 PM
RapidRobert
What a terrible screwup . When you get to that point to preoil before you pull the dist/intergear set the rotor on #8 then pull em & preoil at that position then turn the crank CW 3/4 turn till the timing marks are on TDC (rotor would have been on #6) & preoil the other head
[Re: RapidRobert]
#1563059
01/14/14 03:26 PM
01/14/14 03:26 PM
Posts: 21,074 Niles , Ohio
therocks
Niles , Ohio
Do as stated but pull the valve covers and intake valley pan if BB.Let it sit for a day or so.Vapors can still be hiding in there.Had a GM at work that was flooded almost as bad.Guy tried to start it and the vapors went boom.Blew the valve covers off.Luckily it didnt do more damage.Rocky
Chrysler Firepower
[Re: fc7_plumcrazy]
#1563061
01/14/14 11:58 PM
01/14/14 11:58 PM
Posts: 6,167 Maryland
GO_Fish
Maryland
does it still have the mechanical fuel pump plumbed in series with the electric fuel pump? If so, you may want to check the mechanical pump. There is a rubber diaphragm inside that can tear, and let fuel dump into the crankcase.
Scott B.
"I'm a self-made man... I started with nothing, and I still have most of it!"
68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph
69 340 GTS stock 14.18@ 95.60 mph
01 5.9L Ram 1500 Quad Cab 4x4
01 3.5L 300M 16.23@ 86.97 mph
[Re: fc7_plumcrazy]
#1563062
01/15/14 01:35 AM
01/15/14 01:35 AM
Posts: 43,211 Bend,OR USA
Cab_Burge
I would drain the oil pan and leave the drain plug out and then pull the spark plugs and valve cover breathers, I would then put a small heater under the oil pan, not close enough to scorch the paint though and let it warm the motor up for several days to help make all the gasoline evaporate I would then, as already suggested, remove the oil filter and put a new one on(fill it with oil before installing it ) and put the oil pan drain plug back in and fill it up with oil, as cheap as possible oil, and prime it, after it has oil pressure bump the starter over a little at a time multiple times for several mintutes and then drain the oil out and see how bad the oils stinks like the gasoline over thier If that batch didn't smell, stink, really bad I would then change the oil and filter agian and also put the spark plugs back in and try and start it After it runs for a very short while drain the oil and change the filter again and see how that works, make sure,if it has a flat tappet cam, a non roller cam, to use oil that has a decent zinc content or use a zinc additve, before starting the motor the first time Good luck, BTW what year and body style and motor are you working on?
[Re: ademon]
#1563065
01/15/14 12:30 PM
01/15/14 12:30 PM
Posts: 440 Canada
Dons Dart
Canada
i would only run the new oil for a couple minutes then change it, then next time till the engine fully heats then change again. if it smells ok then run it.
X2
[Re: Cab_Burge]
#1563066
01/16/14 02:55 PM
01/16/14 02:55 PM
Posts: 926 MICHIGAN
BB65Barracuda
MICHIGAN
Once you get it aired out and clean oil you will be fine.
1957 Power wagon wm300 original 10.000 mile truck, 1964 dodge Polara Convertible numbers matching
[Re: 70EK2Bird]
#1563069
01/17/14 03:09 PM
01/17/14 03:09 PM
Posts: 5,610 Germany
fc7_plumcrazy
Germany
Just a question, how did the shipping company get it to you? Did they start it to move off the boat and on to a trailer? Did they cause more damage already?
AFAIK they didn't run it. But the carb was damaged, too so it might have been started and they got a back fire? Who knows?
When we got it pushed off the truck we noticed it won't start After checking the carb we knew why it won't start as it was closed. We opened it. Put a fresh battery in the car and it started. Ran bad and got shut off after 15 seconds by us. Pushed it into the garage. then we checked everything in detail and noticed the small on the oil pick up.
