2008 Ram fueling problems? #1562979
01/14/14 12:13 AM
01/14/14 12:13 AM
Houston, Texas
Slant6pak Offline OP
Houston, Texas
Hey guys,
Any Ram owners out there experience fueling problems? My 2008 Hemi Ram suddenly will not fill with gas. Its acts like it is not venting properly and fuel backs up in the filler neck....
Any thoughts?
2016 Challenger Scat Pack Shaker smile
1000 ci Brass Era Speedster project
Re: 2008 Ram fueling problems? [Re: Slant6pak] #1562980
01/14/14 05:02 PM
01/14/14 05:02 PM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
There are several things that can cause you issue. A blocked or kinked vent hose is common. I have seen them melt and collapse the plastic vapor tubing near the charcoal canister from heat from the exhaust.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: 2008 Ram fueling problems? [Re: 71yelladustr] #1562981
01/18/14 05:07 PM
01/18/14 05:07 PM
Buford, GA
I_bleed_MOPAR Offline
Buford, GA
One of the most common things I saw on Toyotas (before I retired ) was a blocked vent tube by a mud dauber nest.
Tim
'71 Charger 383/727
'17 Challenger SXT (Wifeys car wink )
