Dry Sump oil pans #1562829
01/13/14 06:39 PM
01/13/14 06:39 PM
Edmonton, Alberta, Canada
Lance6611 Offline OP
I don't post here very often but I check the site out everyday. I am considering going to a dry sump system to gain ground clearance in my Arrow chassis car.I would like to keep the dry sump pump and the tank on the oil pump side and was looking for drawings or pictures of oil pan designs so I can fabricate a pan of my own. Is there anything else I must change in order to switch over. Thanks
Re: Dry Sump oil pans [Re: Lance6611] #1562830
01/13/14 08:00 PM
01/13/14 08:00 PM
AndyF Offline
AndyF  Offline
BB or SB engine? I have some dry sump pans for sale for both engines. One of them might work for you.
Re: Dry Sump oil pans [Re: Lance6611] #1562831
01/13/14 08:23 PM
01/13/14 08:23 PM
MR_P_BODY Offline
MR_P_BODY  Offline
My dry sump pan was a roundy round pan... the pick
ups were on the right side but I welded them closed
and run the picks through the pan and exit on the
drivers side.. pretty easy... I welded the tubes to
the AN fittings then welded the fittings to the pan...
sorry I didnt take any pics... I run 2 pick ups in
the pan with a wall at the #3 bearing area so 1 pick
up is in front of that wall and the other is at the
back... plus I put in the one way screen for helping
windage
Re: Dry Sump oil pans [Re: Lance6611] #1562832
01/13/14 08:36 PM
01/13/14 08:36 PM
Big block. Thanks for the replies
Re: Dry Sump oil pans [Re: Lance6611] #1562833
01/14/14 01:16 AM
01/14/14 01:16 AM
AndyF Offline
AndyF  Offline
I have this pan for sale. It is fairly low profile. It is set up for a 5 stage pump but I've run it as a 3 stage setup before and it worked okay.
Re: Dry Sump oil pans [Re: AndyF] #1562834
01/14/14 04:58 PM
01/14/14 04:58 PM
St.Louis, Mo.
mokid Offline
mokid  Offline
St.Louis, Mo.
My question is why? I run a dry sump on my motor and its a pain, with the pump, and hoses,tank,filter it takes up alot of space.
Re: Dry Sump oil pans [Re: Lance6611] #1562835
01/14/14 05:40 PM
01/14/14 05:40 PM
oh
julian2007 Offline
julian2007  Offline
oh
just put a dragster pan on it its almost as short as a drysump pan (I know I run them both ) If you are going to a dry sump system for ground clearance only its a very expensive way to do it. 4000.00 for a system that is not a used bunch of crap.
I think a friend of mine has a used dragster pan for sale I think he wants 150.00 for it, I will measure it and let you know what it is.
God made cold beer,good friends,hot ladies and race cars don't spit in his face by pi$$ing and moaning about how life sucks!!!
Re: Dry Sump oil pans [Re: julian2007] #1562836
01/14/14 07:48 PM
01/14/14 07:48 PM
I get a very uneasy feeling whenever I brake after a run and the oil pressure goes to 0. I thought the dragster pans are designed for motors that are shut off right after the run. I agree that a pan like that if it could control the deceleration oil slosh would be much easier.
Re: Dry Sump oil pans [Re: Lance6611] #1562837
01/14/14 08:28 PM
01/14/14 08:28 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Baffles and trap doors in the pan IF there is oil in the pan
Re: Dry Sump oil pans [Re: Lance6611] #1562838
01/15/14 12:53 PM
01/15/14 12:53 PM
oh
julian2007 Offline
julian2007  Offline
oh
They do have trap doors in them to catch the oil when you lift. I had one going 7.50's all day long with no problem and I never shut it off after a run. Sorry I did not get a chance to measure that pan but I will get to it asap
Bruce
Re: Dry Sump oil pans [Re: MR_P_BODY] #1562839
01/15/14 03:47 PM
01/15/14 03:47 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I have said this before and maybe it bares repeating here. There is HP in a GOOD oil pan period! It sees to be one of those areas guys dont seem to want to or like to spend money on. Windage is an inherent issue with a BB Mopar. Control that windage and the resulting oil in suspension will make power. A properly designed pan will make power, control windage and will be able to control oil on decel. Just saying
Re: Dry Sump oil pans [Re: Al_Alguire] #1562840
01/15/14 10:32 PM
01/15/14 10:32 PM
Saskatchewan, Canada
cudabin Offline
cudabin  Offline
OK Al,
I currently have a Charlie's pan on my Cuda, but would be interested in a better pan... What do you recommend? Anyone use o-ring seal?
I hate the oil leaks I am having now. Good thing I have a vaccum pump, but it leaks in the trailer.
Still using torsion bars, and draglink goes through the pan.
Ideas?
Arne
67 Cuda 8.48@ 158.7 mph 1.18 60' 2,600 DA(so far...) 70 Super Bee 440 Six Pack 4-speed. 13.2 @ 104 Stock exhaust/Street tires.
Re: Dry Sump oil pans [Re: cudabin] #1562841
01/19/14 09:46 PM
01/19/14 09:46 PM
cudabin Offline
cudabin  Offline
Bump!
Lets keep talking about oil pans...
Arnie
Re: Dry Sump oil pans [Re: cudabin] #1562842
01/19/14 11:12 PM
01/19/14 11:12 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Arnie IMO if you need to run a drag link through the pan thee is not much you can do. My suggestion is find a way to use a dragster style pan and then you can begin to worry about oil control. For what you have a scraper and windage tray is about all you can do.
Re: Dry Sump oil pans [Re: Al_Alguire] #1562843
01/20/14 04:21 PM
01/20/14 04:21 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Ask for this for Christmas
2011 Drag Pak Challenger
Re: Dry Sump oil pans [Re: rickseeman] #1562844
01/20/14 04:54 PM
01/20/14 04:54 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I have this pump I'm selling pretty cheap... I never
ran it but it is a used one(came off a Viper build
we were doing then they changed directions).. it had
dyno time on it
Re: Dry Sump oil pans [Re: MR_P_BODY] #1562845
01/20/14 04:56 PM
01/20/14 04:56 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
MrP is that a Dialey pump? If so shoot me a PM
Re: Dry Sump oil pans [Re: Al_Alguire] #1562846
01/20/14 05:02 PM
01/20/14 05:02 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Pretty sure thats the name... here is the other side
Re: Dry Sump oil pans [Re: rickseeman] #1562847
01/20/14 09:45 PM
01/20/14 09:45 PM
cudabin Offline
cudabin  Offline
Rickseeman,
What exactly is that? a combo dry sump and pan deal??
Arnie
Re: Dry Sump oil pans [Re: cudabin] #1562848
01/21/14 01:20 AM
01/21/14 01:20 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Dailey's billet pan with dry sump pump, no hoses.
