Pst e body torsion bars. Fitment #1562784
01/13/14 04:33 PM
01/13/14 04:33 PM
Oh Canada
E
EV2CUDA Offline OP
EV2CUDA  Offline OP
E
Oh Canada
Installed 1.03 bars in my car and wonder if I did it right.
Had them in the first time and could hardly get the adjuster in, but did after lots of effort. The car sat way too high. I pulled the bars back and put the lower arm in a turn to make it easy to put the lower arm in. Now I have to crank the adjuster almost all the way to achieve proper ride height.
Is this good or have I done something wrong?
71 Barracuda 383 4spd (500ci)
69 camaro 598, NOS
69 barracuda bbc procharger
77 t/a 6.0 turbo project
78 t/a 400
77 corvette
1983 hurst/olds
03 Viper
79 360 macho
71 demon 360
78 Warlock 5.7 hemi project
Re: Pst e body torsion bars. Fitment [Re: EV2CUDA] #1562785
01/13/14 04:50 PM
01/13/14 04:50 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
This is a problem PST bars have with their clocking. Check and see if you have ANY clocking with your hexes front to rear. They have since addressed this problem and all their new bars are clocked right, if yours are not I would send them in to get replaced with the new ones.
Mopar to the bone!!!
Re: Pst e body torsion bars. Fitment [Re: 72Swinger] #1562786
01/14/14 02:12 AM
01/14/14 02:12 AM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
It's easy really, compare the clocking from the bars you are replacing- they should be the same, those bars aren't stiff enough to have no offset. Pictured are .92/1.0" a body bars
You also need to be aware of the fact that stiffer bars require less preload, so you will have to back the adjusters off to retain the same ride height, I've found it best to just back the adjuster screw off until it doesn't protrude from the adjuster during the installation.
Lastly, you can install the bars incorrectly, front to back and they will not have the correct ride height- due to the offset of the hexs on the bars.
Re: Pst e body torsion bars. Fitment [Re: Skeptic] #1562787
01/14/14 01:44 PM
01/14/14 01:44 PM
Oh Canada
E
EV2CUDA Offline OP
EV2CUDA  Offline OP
E
Oh Canada
How do I know if it is in right? No instructions!
69 camaro 598, NOS
78 t/a 400
77 corvette
1983 hurst/olds
03 Viper
79 360 macho
71 demon 360
Re: Pst e body torsion bars. Fitment [Re: EV2CUDA] #1562788
01/14/14 05:23 PM
01/14/14 05:23 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
You cant put them in wrong. Think about it, the crossmember hexes are always the same, so flipping the bar end for end will change nothing.
Re: Pst e body torsion bars. Fitment [Re: EV2CUDA] #1562789
01/14/14 06:24 PM
01/14/14 06:24 PM
AndyF Offline
AndyF  Offline
Some of the aftermarket torsion bars are not designed correctly. Evidently the mfgs weren't quite smart enough to think about the issue of hex indexing.
As the bar gets stiffer the hex indexing becomes very important. If the indexing is incorrect then the car will sit too high or too low and you won't be able to adjust the ride height.
The guys at Firm Feel will custom index bars for you if you know what you need. On a really stiff bar you basically have to mock it up and take some measurements. If you know some basic math you can calculate the twist given the diameter of the bar and the weight of the car. Once you have a base line for your car it is easy to build a spreadsheet that will kick out bar size and twist. Then you can specify how much offset you want on the bars when they are built.
Re: Pst e body torsion bars. Fitment [Re: AndyF] #1562790
01/20/14 10:58 PM
01/20/14 10:58 PM
Oh Canada
E
EV2CUDA Offline OP
EV2CUDA  Offline OP
E
Oh Canada
Pst now makes the bars with 20 degree offset. Mine have 0. They will exchange at no cost, just shipping of course.
69 camaro 598, NOS
78 t/a 400
77 corvette
1983 hurst/olds
03 Viper
79 360 macho
71 demon 360
