Re: Mod Man intake.
[Re: bobby66]
#1562601
01/13/14 12:07 PM
01/13/14 12:07 PM
Posts: 12,395 Taxes & Virus's R-US, NY
Dragula
Nice looking set-up. I was thinking they looked like the old Rat Roaster intakes for the Hemi.
yeah a little, but without all the flow issues hopefully...Modman is an open plenum short runner intake. The goal of the rat roaster was a lowered tunnel ram and therefore made getting air and fuel into the lengthened runners a real pain.
Re: Mod Man intake.
[Re: Mopar Guy]
#1562603
01/13/14 12:42 PM
01/13/14 12:42 PM
Posts: 2,103 East Coast, NJ
fig426
East Coast, NJ
I would realy like to see if they are any good at delivering more HP ! So far they look like to big in the plenum and short runners and there have been alot of those done in the past for multipel carbs as Edelbrocks STR intake for an exampel that whas a total disaster when more then one carbs whas on the lid if the one´s that say they tryed are corekt
I put one on my hemi 2 years ago and took off the Vanke modded factory intake. I also went from the factory carbs to a pair of new eddy 750's. I picked up .3 in the 1/4. I don't know if that was the carbs, the intake, or the combo, but probably a little of both. My 60 foot didn't change, but had traction problems with the new setup. Then a few passes later I dropped a valve and haven't been back since. $$$$. I'm sure if I could have resolved my traction problems, my 60 foot would have come down and I would have picked up more overall. So, in short, I was happy with the upgrade, but once again, it was an upgrade from the factory intake and carbs.
Chris from New Jersey
Re: Mod Man intake.
[Re: fig426]
#1562604
01/13/14 03:17 PM
01/13/14 03:17 PM
Dragula
Were either set of carbs tuned for the combo? Most guys that have factory carbs have never once changed a jet in them, and a calibration from the 1960's does not work on today's fuels so I am curious because .3 is a big jump. What ET did it run before and with what mph, and what did it change to? MPH is Hp directly...
Re: Mod Man intake.
[Re: Dragula]
#1562605
01/13/14 10:04 PM
01/13/14 10:04 PM
fig426
East Coast, NJ
Yes, the original carbs were tuned to the combo. Lots of test and tunes on those old carbs!! .. It ran consistant mid 11.20's @ 122mph. Put the modman and 750's on, and listened to advice from some old-timers on the initial jetting, and went straight to 10.97 @ 125mph. That's without any major test/tune because I dropped a valve, and well, it still sits in the garage apart. Hopefully this summer I'll be out again. As always, $$$$....
Re: Mod Man intake.
[Re: fig426]
#1562608
01/13/14 11:50 PM
01/13/14 11:50 PM
Dragula
Cool, so the carbs weren't that bad. I would say it works then. We have had our eye on the Modman intake, but have not had a chance to try one yet. I have run just about every other intake there is on a Hemi, and after seeing the above mentioned Vanke intake and seeing what the FAST guys do to them, I am pretty sure they work well. Even on the small blocks they got a very good write up with them.
Was the dropped valve because of an over rev at all? Been there done that....Sorry to see that.
Re: Mod Man intake.
[Re: Dragula]
#1562609
01/14/14 12:20 AM
01/14/14 12:20 AM
fig426
East Coast, NJ
I don't believe I over revved it, but ya never know. My rev limiter should have jumped in if I got too high, but again, ya never know. I haven't even tested the spring yet to see if it's weak. That's my guess of what caused it. I was so disgusted, I just parked it, tore it down, and have been slowly picking away at it. Once again... $$$$.... I'll be doing the heads soon so I'll test the springs then and that should give me a better idea of what may have happened. The valve actually broke when the engine was cold, on initial startup upon arriving at the track. There is a distinct line on the stem where it can be seen that the stem had cracked, then broke. It just didn't snap off in one clean break...if that description makes any sense. So who knows
Re: Mod Man intake.
[Re: fig426]
#1562610
01/14/14 01:21 AM
01/14/14 01:21 AM
Posts: 2,464 Sydney,Australia
tex013
Sydney,Australia
Ron , good to see how your brother is going . I still have mine on the shelf . Wait till after this 2014 season before I try it again . Like I have said would like to try it on my new heads - or a stroker Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
Re: Mod Man intake.
[Re: tex013]
#1562611
01/14/14 02:41 AM
01/14/14 02:41 AM
Posts: 3,943 Melbourne.....Oz-land
Moparmal
My only complaint has been the need for a much bigger pump shot than my vac sec. 800 Eddie could provide.
As soon as I tried a double pumper, the lean out issue I had disappeared.
Again, not sure if this was down to the MODMAN plenum or the huge Gen3 port runners.
67 RO23 clone with 6.1 SRT Hemi and dual quads. Soon to have Drag Pak induction and Throttle body.
Re: Mod Man intake.
[Re: MadMopars]
#1562613
01/14/14 05:19 AM
01/14/14 05:19 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
What intake was he running prior? Any noticeable gains or track time to see how it measures up?
The bummer is this is a new eng and so far this is the only intake he has run. He runs in the NSS class and has to run two carbs and he is going back to the stock size Hemi scoop and getting rid of the higher size scoop. So he cant run a tall intake and he felt this Mod Man intake should be better then the Mopar crossram. This is a 505 low block stroker and I believe he has only had it out twice last year as his trans started slipping so he is pulling the trans this week to go thru it. Best run so far in his 64 Fury which goes about 3600 with him in it has been 10.08 I believe and its only got about 7 passes on the new combo. Ron
