? for MR.P......Or anyone with a resolution #1561910
01/11/14 08:34 PM
01/11/14 08:34 PM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
A while back you had made a post on your a-pillar bars/dashboard ,concerning fitting the dashboard around the bars(a-pillar).Do anyone remember the name of that thread that was started?......Thax.
Re: ? for MR.P......Or anyone with a resolution [Re: racerx] #1561911
01/11/14 08:48 PM
01/11/14 08:48 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Sorry that was on someone elses post so I dont recall...
but what is your question... IF I can help I would
be more than happy to
Re: ? for MR.P......Or anyone with a resolution [Re: racerx] #1561912
01/11/14 08:51 PM
01/11/14 08:51 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Isn't that the yellow duster with the vinyl roof? Did his own cage work?
Re: ? for MR.P......Or anyone with a resolution [Re: MR_P_BODY] #1561913
01/11/14 09:03 PM
01/11/14 09:03 PM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
When you were fitting your dashpad around the a-pillar bars what was your resolution for the pad that fitted between the bar and the windshield?someone had made a post on this and i thought it may have been you....Sorry
Re: ? for MR.P......Or anyone with a resolution [Re: racerx] #1561914
01/11/14 09:47 PM
01/11/14 09:47 PM
MR_P_BODY Offline
MR_P_BODY  Offline
When I did the Rampage I kept the bars as close as
possible to the A-pillar and then used the padding
to cover the front slot... but to be honest I'm taking
the roll bar padding off and I will trim in a piece
to fit (its not much)
Re: ? for MR.P......Or anyone with a resolution [Re: MattW] #1561915
01/11/14 09:51 PM
01/11/14 09:51 PM
That's the one, and yes he did an awesome job.
Re: ? for MR.P......Or anyone with a resolution [Re: ] #1561916
01/11/14 11:59 PM
01/11/14 11:59 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Are you sure it wasn't JBMopars Gold duster?
Re: ? for MR.P......Or anyone with a resolution [Re: ProSport] #1561917
01/12/14 12:02 AM
01/12/14 12:02 AM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
