69 GTX upper door frame plastic plugs #1561719
01/11/14 02:37 AM
01/11/14 02:37 AM
I know on my charger, the upper door frame plugs that covered the access holes for the vent window frame bolts were interior colored plastic. On our mostly unrestored 69 GTX vert, the plugs were black plastic while the interior is the T7 bronze color. Granted, everything with the interior of the car was all original with the exception of the seat covers and carpeting which were replaced due to fading. I would like to put the plugs back in the correct color if they are indeed supposed to be interior color and not black. Can anyone shed some light on what would be correct?
Re: 69 GTX upper door frame plastic plugs [Re: ] #1561720
01/11/14 02:45 AM
01/11/14 02:45 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Not sure if they came in all of the upper door frame matching colors but then again my '68 road runner in green had matching green plugs. You may have to paint them to match?
I'm going to look at some photos of survivors to see if they all match the upper door frame color, back when I find out but sure someone will chime in before that.
Re: 69 GTX upper door frame plastic plugs [Re: A12] #1561721
01/11/14 03:32 AM
01/11/14 03:32 AM
I was thinking they were matched to the color of the interior but with 44 years on the car, its hard to tell if they were changed out or not. With how badly faded the sun visors were, I could see how the plastic would have dried out and became brittle and broke and then replaced with the generic black plugs.
Re: 69 GTX upper door frame plastic plugs [Re: ] #1561722
01/11/14 04:23 AM
01/11/14 04:23 AM
PORT ALBERNI , BC., CANADA
superwrench Offline
superwrench  Offline
Both my '68 GTX and the parts car had maroon guts....those plugs were maroon in both cars.
Re: 69 GTX upper door frame plastic plugs [Re: superwrench] #1561723
01/12/14 11:51 PM
01/12/14 11:51 PM
Orleans, Ontario
moparcanuk Offline
moparcanuk  Offline
Orleans, Ontario
The plugs should match the interior colour.
Re: 69 GTX upper door frame plastic plugs [Re: moparcanuk] #1561724
01/13/14 03:07 AM
01/13/14 03:07 AM
Just so we are talking about the same plastic plugs..... The ones closest to the hinges.
Re: 69 GTX upper door frame plastic plugs [Re: ] #1561725
01/13/14 04:26 AM
01/13/14 04:26 AM
superwrench Offline
superwrench  Offline
That's the ones
Re: 69 GTX upper door frame plastic plugs [Re: superwrench] #1561726
01/14/14 06:43 PM
01/14/14 06:43 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
HaH! i remember those from my Road Runner. crumbled up bit of whaite plastic (white interior) when i replaced them. only thing i know available is black.
Re: 69 GTX upper door frame plastic plugs [Re: mikemee1331] #1561727
01/15/14 12:37 AM
01/15/14 12:37 AM
motor city
sixty9redgtx Offline
motor city
On my 69 GTX with R6 red interior the door plugs are black.
Re: 69 GTX upper door frame plastic plugs [Re: mikemee1331] #1561728
01/15/14 03:37 PM
01/15/14 03:37 PM
Back In Iowa
belv2vert66 Offline
belv2vert66  Offline
Back In Iowa
I wondered the same thing.....who sells the colored ones ? I need white if they exist...
Re: 69 GTX upper door frame plastic plugs [Re: belv2vert66] #1561729
01/15/14 04:04 PM
01/15/14 04:04 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
I looked into this when I was doing my 'Bee and ascertained they should be interior colored (F8) in my case. Couldn't find a source so I had to use black ones.
Perhaps the plugs weren't available in every color. ...but green ones were for sure
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: 69 GTX upper door frame plastic plugs [Re: belv2vert66] #1561730
01/15/14 04:04 PM
01/15/14 04:04 PM
Doesn't seem to be anyone out there who sells the colored plastic plugs. They only seem to be available in black and then you have to paint to match which I think the colored plastic was never a perfect match to the interior paint anyways.
Re: 69 GTX upper door frame plastic plugs [Re: DPelletier] #1561731
01/15/14 04:07 PM
01/15/14 04:07 PM
Dave,
We are lucky enough to still have the small rubber plugs that go in the hole in the middle of the upper door frame and they are in perfect shape. Quite possibly due to different plastic/rubber make up as they seem to be more of a rubber plug than a plastic plug.
Re: 69 GTX upper door frame plastic plugs [Re: ] #1561732
01/15/14 04:47 PM
01/15/14 04:47 PM
Eastern shore, New England
roadrunner69s Offline
Having owned 4 orig paint '69 B Bodies over the years I was sure I'd have photos showing these plugs closest to the door hinges But, all I could find was the bronze '69 GTX showing the outer door/latch side. But that lower round plug is black against the bronze paint. The factory made no effort to put a body colored plug there. Then again, upper door frames were black on this black interior car.
Couldn't find close up photos of the inner door jamb areas. I'd guess that the factory in 1969 put in black plugs on many cars, regardless of UDF or body color. I could be very wrong though. The plugs don't show, so what factory assembler would really care? The door bumpers are all black. And you have black drain plugs in the trunk floors as well. Black goes with everything. They did make the effort to match the door lock lift/push knobs to the UDF paint color.
Re: 69 GTX upper door frame plastic plugs [Re: roadrunner69s] #1561733
01/15/14 07:54 PM
01/15/14 07:54 PM
DPelletier Offline
DPelletier  Offline
It was all a plot to make it more difficult for us to restore these cars 40 years later...
Re: 69 GTX upper door frame plastic plugs [Re: ] #1561734
01/15/14 08:26 PM
01/15/14 08:26 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
1969 Charger, original, unrestored, only 1 repaint in 1986
Re: 69 GTX upper door frame plastic plugs [Re: DAYCLONA] #1561735
01/15/14 08:28 PM
01/15/14 08:28 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
1969 Road Runner, original, unrestored, recent vinyl top, exhaust, wheels, that's it
Re: 69 GTX upper door frame plastic plugs [Re: DPelletier] #1561736
01/15/14 10:17 PM
01/15/14 10:17 PM
yeh, ain't that the truth!
Re: 69 GTX upper door frame plastic plugs [Re: DAYCLONA] #1561737
01/15/14 10:30 PM
01/15/14 10:30 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
pretty sure this is original paint and original plugs
Re: 69 GTX upper door frame plastic plugs [Re: A12] #1561738
01/15/14 10:33 PM
01/15/14 10:33 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
and this one too but at first I thought you were asking about the small plug in the top center of the upper door frame (arrows) that always seem to be upper door frame color like the are in when painted
