Re: Big Block Hughes Whiplash Cam
[Re: Fastfrankie]
#156166
11/25/08 12:45 PM
11/25/08 12:45 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
When is the intake valve closing event at .050? You're missing numbers there...
[Re: Fastfrankie]
#156169
11/25/08 11:54 PM
11/25/08 11:54 PM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
Intake Valve Lift 1.5 .518"
Exhaust Valve Lift 1.5 .518" Intake Duration at .050" 232°
Exhaust Duration at .050" 245°
Lobe Separation Angle 107º
Intake Opening at .050" 12° BTC
Exhaust Opening at .050" 52.5° BBC
Intake Closing at .050" 40° ABC
Exhaust Closing at .050" 12.5° ATC
Yep, pretty much what I thought. To have the timming points above the cam would have to be installed with a 104 intake centerline. This gives Intake closing at 0.050" = 40 ABDC Exhaust Opening at 0.050" = 52.5 BBDC
I think it should work good.
