Re: E-Body Alternator/Regulator/Bypass - What IS the best?
[Re: Steve Bryant]
#1561426
01/10/14 02:20 PM
01/10/14 02:20 PM
RapidRobert
(as you know) many ways to go. (1) I would clean ALL terminals/connections especially the bulkhead (wire brush on the male terminals/NAPA 725147 male terminal to clean the female ones). (2) do Nacho's 2 wire bulkhead bypass. (3) keep the ammeter (4) relay the stereo & if desired maybe the lights/heater to the alt (good idea). (5) keep the current alt & if it dies then upgrade to 85 M body 78 amper or a Denso (far better but diff brackets needed). (6)koppercoat (sp) on the terminals. You want to keep the ammeter needle as close to 12 0'clock as possible & the solution is to via a relay(s) power all devices right from the source (the alt). This keeps excess current out of the bulkhead/underdash EDIT that is not a long post! (& I enjoyed it) & the reg (electronic I am assuming) will be fine
[Re: Steve Bryant]
#1561428
01/10/14 04:52 PM
01/10/14 04:52 PM
Posts: 3,277 West Coast, USA
jbc426
West Coast, USA
What's the AMP draw from the stereo? How big is the recommended fuse that feeds the power supply to you amplifiers?
The problem with Mopar & Denso alternators is that they don't put out a lot of amperage at idle, or even at 1200 to 1500 or rpm for the Mopar type.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: Steve Bryant]
#1561429
01/10/14 05:46 PM
01/10/14 05:46 PM
RapidRobert
Phase 1 will bypass the ammeter & keep some of the load out of the bulkhead because of the parallel bypass. Phase 2 will do the same thing but restore the ammeter. All good there. Critical would be to (1) relay the stereo so it gets fed from the black wire between the alt & the firewall (2) clean/koppercoat all terminals/connections
[Re: RapidRobert]
#1561430
01/11/14 12:08 PM
01/11/14 12:08 PM
Posts: 1,526 North Carolina
cjskotni
North Carolina
These are all good ideas to do the parallel bypass if you are using the original wires and amp gauge which is 40+ years old at this point. FWIW, a 100 amp alternator can be made to work on factory wiring/ammeter just fine IF the wires everywhere are in good shape (or new harness) and you keep some things in mind:
- part of the excessive current being pulled through the harness/bulkhead is not due to high alternator output but actually do to low output (at idle mostly) where the battery would discharge and the charge sharply once the car took off. If the factory alternator put out good charge at idle, the battery would not discharge and then have to 'catch up' when the engine picked up RPM's. So my point is for stock type loads and clean wires/terminals having a higher output amp will place the same or LESS strain on the charging circuit wires.
- You can get into trouble when you don't consider where you pull any non stock electrical loads off the charging circuit. Think fuel pumps, fans, hi current amps, etc. People tend to want to want to pull power from the battery which is the most obvious choice. However, this will result in all this additional load being pulled through the entire charging circuit and bulkhead while the car runs. This is what burns up wires and makes people fear the original design. These large, constant loads MUST be pulled from the alternator stud. This will result in NO additional load being pulled through the harness/ammeter IF the alternator can meet the demands. Additional load would only flow through the harness in this case if the alternator couldn't keep up and the battery had to discharge to make up for the gap.
I run a 100 amp squareback on my Charger with an original charging circuit. My harnesses are all new and my ammeter has been rebuilt. My currents pulled through the harness (ammeter) are LESS than they were when I had the 60 amp version. The only time I get a wild needle swing in either direction for more than a split second is when I first crank the car and the alternator has to replenish the battery. Oh yeah, and I have electric fans. I have confirmed this with clamp gauges and the ammeter. I can run A/C, electric fans, radio, lights, etc and my charging wires don't get even warm. So yes, it can be done without the bypass but the bypass is probably a 'safer' option if you don't know the condition on your wires end-to-end and understand how the charging circuit works.
One last point, I wouldn't worry about relaying a stereo. If the stereo is modern and you aren't installing external amps, the stereo current draw will be negligible. I have a 50X4w stereo that draws maybe 2-3 amps if I crank it way up and it's hitting a beat. In fact the factory fuse on it is a whopping 5 amps. I can sit in the car and crank the thing up to where its making my ears bleed and the ammeter barely moves with the car OFF.
[Re: cjskotni]
#1561432
01/13/14 01:17 PM
01/13/14 01:17 PM
Posts: 4,453 Morristown Tn.
71birdJ68
Morristown Tn.
Cksjotini, I don't want to steal the thread, but there are a lot of people in the same boat as the OP, and just are not sure which way to go. I'm kinda like him in that I thought I knew what to do, but now I'm not sure. So if you will let me tell what I have maybe we all can get something done together. I have a 71 RR ,I want a completely stock look, but with some modern stuff hidden out of sight.The harness firewall forward is new, I had a 60 amp stater put in the original Alt, and I had the amp meter studies welded. The car was protected all its life and the inside harness is in like new shape. The only extra draw is a BIG stereo amp I installed under the package tray out of sight. It has a built in 20 amp fuse for each channel. I ran a big power wire to the engine compartment, and now I'm not sure where to hook it up. I was going to hook it to the stud on the starter so it wouldn't be seen, but after reading all this should I run it to the alt?
[Re: 71birdJ68]
#1561433
01/13/14 01:36 PM
01/13/14 01:36 PM
RapidRobert
In my earlier post I had assumed that stereos drew alot of power. If that ain't the case then you could likely get by with powering it from the eng side of the bulkhead but I would definitely do Nacho's parallel bypass & you could drill thru the bulkhead & wire it straight thru for a hidden look. with good/clean connections/terminals the #1 problem is the bulkhead & it's a good idea to relay as much as possible directly to the alt especially the headlight/heater. this keeps the ammeter honest. I would stay with the OE type alt not a 1 wire.
[Re: Jerry]
#1561436
01/13/14 02:59 PM
01/13/14 02:59 PM
71birdJ68
Morristown Tn.
Yes, it is switched, it has a separate wire that goes to the stereo, and only comes on when the stereo is on. Do you mean hook to the starter relay?
[Re: Steve Bryant]
#1561442
01/13/14 07:22 PM
01/13/14 07:22 PM
cjskotni
North Carolina
cjskotni, Thank you for the detailed reply. I had the pleasure of speaking with Mark from MadElectrical.com for about 3 hours on Friday and he taught me far more than I will ever remember. I ended that call and thought I knew exactly what was needed; Single Wire, Bypass, replacing ammeter with voltmeter, and new relays for lights and everything else above-and-beyond stock. Of course none of that is stock and most of it is obvious to even the casual observer. His argument is that a "driver" needs to be more modern to be safe whereas a fully factory car should be (I am paraphrasing) parked and babied due to inadequate charging and electrical problems. Is yours a daily driver? Do you take long trips with it?
These is nothing wrong at all with doing the parallel bypass and converting to a volt meter. It gives you the flexibility to run much larger cable on the charging circuit which is never a bad idea. I was making the point that a restored factory type circuit with even a hi-amp alternator can work just fine if you wire it correctly. When I pay nearly a grand for factory replica harnesses + gauge rebuild, I am not splicing and drilling.
FWIW, I have taken this car on 50 mile trips so far and once the alternator has topped of the battery after startup, it stays damn near dead center all the time. This indicates little to no current flow to/from the battery. The constant discharge/charge cycles of the underpowered factory alternator is what kills the wiring and makes heat up and burn.
Another note that relays will NOT (repeat WILL NOT) fix and underpowered alternator charging issue. Relays are designed to provide a more direct path for current to flow from the charging circuit to the powered device (headlights) thereby providing a minimal voltage drop which gives brighter headlights. This also has the effect of taking the load off of the headlight switch which will allow it to run much cooler and longer. However, the relay will lower the resistance of the headlight circuit (due to the elimination of the in-line switch + small wiring) which will lead to MORE current draw from the relayed device.
You would want to take the power for that amp from the alternator charging stud....provided you listen to your music mostly when the car is running. When the car is off, the current to drive it will then have to come from the batter which will lead to a long trip from the battery, thru the bulkhead, back thru the bulkhead and back to the alternator. Putting the power cable at the starter relay would not be a good idea.
If your amp is that big, you are going to be disappointed at the results if you crank the music up. I'd plan on going to AT least a 100 amp alternator. For your case, I'd also recommend a capacitor for the amp to help smooth out the power draw (and voltage drops) from 'beats' in music.
A parallel bypass wouldn't be a bad idea for you as it would provide a solid path to power the amp regardless of whether the car was running or not. However, if you are sure your wiring is that good and you keep in mind the path the current takes running vs. non-running, you should be OK.
Agreed, unless you are going to a modern design alternator, stay away from the one-wire retro crap.
[Re: Steve Bryant]
#1561443
01/13/14 07:33 PM
01/13/14 07:33 PM
cjskotni
North Carolina
So after 3 hours with Mark, I think I can answer the Stereo/AMP question at least with his recommendations. I too have a Big amp bolted hidden under the package tray and I ran a hefty wire up to the battery. Mark's recommendation however is NOT to connect these things to the battery but to a wire distribution that is central to the overall charging system. His opinion is that you move to a 1-Wire or Bypass system so the "central" connection becomes the stud on the starter relay. The regulator will see this load and adjust power accordingly without traversing the bulkhead connectors or underdash weld. I attached a drawing he asked me to make while he explained it. Unfortunately, by default we don't have a good "central" point like this so connecting things to the battery forces the resulting charge to traverse the wiring harness, underdash weld and gauge. Moving to a 1-wire or installing a bypass puts this central point on the starter which means it will take the power directly from a regulated alternator charge unless the car is off, then it pulls from the battery.
Moving to a one-wire changes nothing, just that you don't have field wires going to the regulator. I wouldn't waste your time with going to the starter relay lug either. Unless you do the bypass, that would still have to pull current from the alternator back thru the bulkhead, dash harness, thru the bulkhead again and then to the lug. As RapidRobert mentioned this will also make your ammeter useless as it will register a discharge when the alt is powering your amp.
If this stereo is going to have an external amp (and therefore draw a considerable load), then just do the bypass with an 8ga or higher wire from the alternator stud to the starter relay stud. THEN you can tap in to the starter relay stud to draw power. Keep in mind, the factory ammeter is useless at this point (if you care). I would also consider installing an in-line fusible link 2 sizes smaller than the bypass wire (eg. 12 ga).
If you are just powering a head unit, tap into the harness and don't worry about it.
