Page 1 of 3 1 2 3
Carter AFB's #1561348
01/10/14 11:01 AM
01/10/14 11:01 AM
gainsville, usa
johnfin Offline OP
johnfin  Offline OP
gainsville, usa
Do all Carter AFB's have the auxiliary airvalves? I have a bunch of AFB's and none of them seem to have that part.
Re: Carter AFB's [Re: johnfin] #1561349
01/10/14 11:27 AM
01/10/14 11:27 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Depends on the application.
Re: Carter AFB's [Re: johnfin] #1561350
01/10/14 03:51 PM
01/10/14 03:51 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Are you referring to the secondary air valve???? If so
The AFB's used an internal counterweighted door above the secondary butterflies. it can be adjusted by adding or removing weight which is a PITA
The AVS's used an adjustable air door on the air horn ( top of the carb).
Re: Carter AFB's [Re: TJP] #1561351
01/10/14 04:36 PM
01/10/14 04:36 PM
gainsville, usa
johnfin Offline OP
johnfin  Offline OP
gainsville, usa
I have a dozen of these carbs, AFB's, and none have the weighted valves above the secondaries. The secondaries are spring loaded, downdraft opens them on full throttle and forced closed by a lever when throttle is released.
Re: Carter AFB's [Re: johnfin] #1561352
01/10/14 05:02 PM
01/10/14 05:02 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Huh? The secondaries are opened mechanically by a link rod from the primaries, the only spring involved is the one in the primaries to prevent the secondaries from opening when the choke is closed.
The use of the weighted air flapper in the secondaries is yes/no; some had it, some didn't.
Re: Carter AFB's [Re: John_Kunkel] #1561353
01/10/14 06:03 PM
01/10/14 06:03 PM
gainsville, usa
johnfin Offline OP
johnfin  Offline OP
gainsville, usa
The ones I have use a spring on the secondaries, its on the passenger side and its a light spring. I think its suppose to keep the secondaries closed when the primaries are a little open. I have to look at mine again but the other night I opened the primaries full and the secondaries did not open.
Re: Carter AFB's [Re: johnfin] #1561354
01/10/14 06:11 PM
01/10/14 06:11 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
If you have a dozen AFB's,can't imagine you have none with any of these.
Re: Carter AFB's [Re: 62maxwgn] #1561355
01/10/14 06:32 PM
01/10/14 06:32 PM
renton , washington
P
perfmachst Offline
perfmachst  Offline
P
renton , washington
hi, the early AFB carbs didn't have weighted air valves above secondary bores. asfar as I remember, those were used up till 1966.
the 235 /273 had weighted valves starting in 1965. the 383 had none. lot of it depended on engine combo. AFB came out in 1960 ?? so you have early AFB carbs.
Re: Carter AFB's [Re: perfmachst] #1561356
01/10/14 06:38 PM
01/10/14 06:38 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
The AFB in my 64 300 did not have the valve under discussion.
Don't be the exception.
Re: Carter AFB's [Re: perfmachst] #1561357
01/10/14 06:40 PM
01/10/14 06:40 PM
Cab_Burge Online work
Cab_Burge  Online Work
Not so Pontiac, Ford and Mopar and other GM motors used Carter AFB, Aluminum Four Barrel starting in 1958, that had the weights on them Some of the smaller C.I. AFB carbs. did not have the weighted air valves under the rear secondary venturi boosters, but some did :shruggy :Most of the bigger C.I. motor carbs. had them stock The Carter Air Valve Secondary, AVS carbs, had the spring loaded door above the secondarys starting in 1968, maybe also the 1967 HP 440 motors, on the HP Mopar motors.
Re: Carter AFB's [Re: johnfin] #1561358
01/10/14 07:09 PM
01/10/14 07:09 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Correct, but the secondaries are still opened mechanically but only after the primaries are open a ways.
That's because the choke was closed; when the choke is closed the secondaries won't open.
Re: Carter AFB's [Re: perfmachst] #1561359
01/11/14 01:43 AM
01/11/14 01:43 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
As far as Chrysler,the weighted air valve started with the dual quad motors in the 58 Fury/D500/Adventurer and 300D and continued through all inline 2x4 systems including the Hemi and various single fours depending on application.
Re: Carter AFB's [Re: Cab_Burge] #1561360
01/11/14 05:03 AM
01/11/14 05:03 AM
renton , washington
P
perfmachst Offline
perfmachst  Offline
P
renton , washington
hi, I wasn't quoting gospel or trying to misinform!!! as i said, as I remember . I wasn't privy to all cars back then!! sounds like your the expert , next time ,I won't make any comments!!
Re: Carter AFB's [Re: perfmachst] #1561361
01/11/14 05:25 AM
01/11/14 05:25 AM
I'm not a expert in anything other than causing hate and discontent when I set my mind to that My post was offered to correct a internet myth before it got spread by those not in the know Bottom line, intent on your part is not the point, the results are
Re: Carter AFB's [Re: Cab_Burge] #1561362
01/11/14 05:32 AM
01/11/14 05:32 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
My 1964 race hemi carb has it
Re: Carter AFB's [Re: ademon] #1561363
01/11/14 05:37 AM
01/11/14 05:37 AM
If those are the OEM Carters they are some rare pieces I had heard that the first race hemi came with Carters but I've never seen any of those 1964 race motors with them Same thing on the NASCAR 410 HP Race hemi with the single four barrels
Re: Carter AFB's [Re: Cab_Burge] #1561364
01/11/14 10:09 AM
01/11/14 10:09 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Learn something every day on Moparts. All the AFB's I have worked on over the years had the weighted air valve and I thought all AFB's had it. Ron
Re: Carter AFB's [Re: Cab_Burge] #1561365
01/11/14 02:47 PM
01/11/14 02:47 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
yes it's a 3861 AFB it doesn't have the numbers stamped on it which I've been told means it was on one of the 70 cars that left the factory. Only have the one
Re: Carter AFB's [Re: 383man] #1561366
01/11/14 03:51 PM
01/11/14 03:51 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
I'm not doubting what is being said here but without the air valve I would think there would be a substantial bog when the secondary's were winged open as there was no secondary pump shot
Re: Carter AFB's [Re: TJP] #1561367
01/11/14 03:57 PM
01/11/14 03:57 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Still depends on the application.
Page 1 of 3 1 2 3
