Re: Viper calipers and rotors installation [Re: dickdale] #1561304
01/16/14 01:09 PM
01/16/14 01:09 PM
Berwyn, IL
challenger70 Offline
Berwyn, IL
Did you make the hubs too Andy? Nice job!
Wouldn't it be nice if these hubs were for sale so you could make you're own setup...
Someone should make a kit, maybe for gen 3 calipers and mustang wheels...
Re: Viper calipers and rotors installation [Re: dickdale] #1561305
01/16/14 05:15 PM
01/16/14 05:15 PM
AndyF Offline
AndyF  Offline
Not enough people would buy the hubs to make it worthwhile. I made hubs for awhile and then gave up. Almost everyone who ever contacted me about hubs wanted custom offset or some other change made to the hub and they wanted it a price which was lower than my manufacturing cost. Not exactly any reason for me to subsidize everyone else's project car when I have a project of my own to work on so I stopped making hubs.
Re: Viper calipers and rotors installation [Re: OzHemi] #1561306
01/16/14 05:23 PM
01/16/14 05:23 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Helps having a mill and lathe in the garage though.
That is like cheating..
Having a lathe and mill at home is a beautiful thing.
- Stu Harmon
Re: Viper calipers and rotors installation [Re: brads70] #1561307
01/16/14 10:11 PM
01/16/14 10:11 PM
Oh Canada
E
EV2CUDA Offline
EV2CUDA  Offline
E
Oh Canada
Brads70. What are you using? Looks good. You made your own hub?
Andy, you should have told em stock location it is...make your rim custom.
I guess locating drum spindles looks to be the easiest way to get it done for a large rotor.
71 Barracuda 383 4spd (500ci)
69 camaro 598, NOS
69 barracuda bbc procharger
77 t/a 6.0 turbo project
78 t/a 400
77 corvette
1983 hurst/olds
03 Viper
79 360 macho
71 demon 360
78 Warlock 5.7 hemi project
Re: Viper calipers and rotors installation [Re: EV2CUDA] #1561308
01/17/14 01:10 AM
01/17/14 01:10 AM
Lethbridge, AB, Canada
dangina Offline
dangina  Offline
I ave one of andy's hubs from his 13" kit, if I remember it's 3/4" longer so you can run the stock mustang wheels because they are cheap like borshe
Re: Viper calipers and rotors installation [Re: dickdale] #1561309
01/17/14 04:07 AM
01/17/14 04:07 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
I'm making another batch of fully machined forged aluminum hubs right now. I can sell them separately, but everyone seems to want a custom offset or register diameter.
Re: Viper calipers and rotors installation [Re: DoctorDiff] #1561310
01/17/14 06:15 AM
01/17/14 06:15 AM
The Netherlands, OV
dickdale Offline
dickdale  Offline
The Netherlands, OV
What will they cost? Without the bearings, hub cap... They bearing size will be stock (for the 73 knuckle) I presume?
Re: Viper calipers and rotors installation [Re: EV2CUDA] #1561311
01/17/14 10:53 AM
01/17/14 10:53 AM
Ontario,Canada
brads70 Offline
brads70  Offline
Ontario,Canada
I used a 73 C-Body spindle and rotor.
Re: Viper calipers and rotors installation [Re: dickdale] #1561312
01/17/14 02:13 PM
01/17/14 02:13 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Bearings, caps and studs are included. You can choose hubs to fit '72 and older, or '73 and newer spindles.
Register diameter is 2.780". Hub nose diameter is 2.700".
I haven't figured pricing yet.
Re: Viper calipers and rotors installation [Re: brads70] #1561313
01/17/14 02:36 PM
01/17/14 02:36 PM
Oh Canada
E
EV2CUDA Offline
EV2CUDA  Offline
E
Oh Canada
I see now you have an adapter for bolt pattern. Do tie rod and ball joints match to the e body?
69 camaro 598, NOS
78 t/a 400
77 corvette
1983 hurst/olds
03 Viper
79 360 macho
71 demon 360
Re: Viper calipers and rotors installation [Re: DoctorDiff] #1561314
01/17/14 07:42 PM
01/17/14 07:42 PM
The Netherlands, OV
dickdale Offline
dickdale  Offline
The Netherlands, OV
Could you let us know? A piece of machined forged aluminum couldn't be that expensive
Re: Viper calipers and rotors installation [Re: EV2CUDA] #1561315
01/18/14 12:18 AM
01/18/14 12:18 AM
Ontario,Canada
brads70 Offline
brads70  Offline
Ontario,Canada
I used a 1/2" spacer, http://www.summitracing.com/int/parts/aaf-all44121/overview/
ball joints upper and lower match the body. You have to slightly machine the lower ball joint holes to match the e-body ball joint. Outer tie rod is a Howe quick bump kit.
Here is a link to what I did step by step?
http://www.cuda-challenger.com/cc/index.php?topic=73985.0
[URL=http://s651.photobucket.com/user/B_Richmond/media/PDRM0869.jpg.html][IMG]
http://www.howeracing.com/p-7449-howe-quick-bump-tie-rod-ends.aspx
http://i651.photobucket.com/albums/uu240/B_Richmond/PDRM0869.jpg[/IMG][/URL]
Re: Viper calipers and rotors installation [Re: brads70] #1561316
01/18/14 12:43 AM
01/18/14 12:43 AM
GA
roadrunninMark Offline
GA
can a hubless rotor just be used on an e / b body drum hub? Seems like that could be a cheap way to go w/o having to get new spindles if you have a drum brake car. Add a pair of adapters and calipers and the big items are done..
Re: Viper calipers and rotors installation [Re: roadrunninMark] #1561317
01/18/14 03:39 AM
01/18/14 03:39 AM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Sure, just find a rotor with the right height for your setup..taking into accout what caliper and wheel you want to run, carve up a bracket and go for it.
Re: Viper calipers and rotors installation [Re: DoctorDiff] #1561318
02/17/14 06:27 AM
02/17/14 06:27 AM
The Netherlands, OV
dickdale Offline
dickdale  Offline
The Netherlands, OV
Have you figured out the pricing?
Re: Viper calipers and rotors installation [Re: dickdale] #1561319
02/18/14 04:35 AM
02/18/14 04:35 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
I just got them back from the machine shop.
Looks like they run $260 pair, assembled.
Re: Viper calipers and rotors installation [Re: DoctorDiff] #1561320
02/18/14 05:21 AM
02/18/14 05:21 AM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
Hey Cass!
I hear you sell 13" rotors with aluminum hats?
You never told me about those!
I would have bought them instead!
73 `Cuda
Instagram: @rylispro
YouTube: RylisPro
www.rylispro.com
925-214-9192
