Re: mustang 5 speed behind mopar 440?
[Re: bigblockbryan]
#1561194
01/09/14 06:43 PM
01/09/14 06:43 PM
Posts: 5,163 CT
GTX MATT
CT
In stock form it absolutely will not hold up for long behind any big block MoPar, especially in a B body, even with bias ply F70s, unless you drive it like a limo
[Re: bigblockbryan]
#1561197
01/09/14 08:43 PM
01/09/14 08:43 PM
Posts: 25,823 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The T-5 has a maximum torque capacity of 265 ft. lbs. or 310 ft. lbs. depending on whether it's the early or late version. A bone stock 440 is rated at 480 ft. lbs.
If you want a 5-speed of that style the TKO500 or TKO600 is the way to go.
[Re: John_Kunkel]
#1561198
01/09/14 08:50 PM
01/09/14 08:50 PM
Posts: 1,144 wellington ohio
68-scatpack-rt
In thin ice
In thin ice
wellington ohio
Yep, tremec TKO is the way to go. I couldn't keep t5's behind a mild 302 in a 3300 pound car.
unions....the folks who brought you the weekend!
[Re: 68-scatpack-rt]
#1561199
01/09/14 11:08 PM
01/09/14 11:08 PM
Posts: 1,035 Missouri U.S.A.
71yelladustr
Missouri U.S.A.
I ripped the teeth off of third gear too many times to count in my 86 GT equipped with a T-5. I will guarantee you will do the same behind a totally stock 440 the first time you try to power-shift it. Dont do it. If you choose to, this -> will lead to this ->
392 gen III hemi on E-85 727 trans Dana 60 10.02@134
[Re: jcc]
#1561202
01/10/14 01:16 AM
01/10/14 01:16 AM
Posts: 6,003 Salem
Grizzly
Moparts Proctologist
Salem
Another vote for the $100.00 overdrive: A833od
That 440 will eat up those wide ratios, heck I have one behind a 318 2bbl in my beater and the gear spreads don't bother it at all.
Mo' Farts
Moderated by "tbagger".
[Re: 5spdcuda]
#1561212
01/10/14 11:59 PM
01/10/14 11:59 PM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
If you can afford it and you're not in a big hurry I would look into the new 855 transmission offered by Jamie Passion
