Re: What hood with a crossram???
[Re: vttm]
#1561118
01/09/14 05:25 PM
01/09/14 05:25 PM
Posts: 1,186 OHIO
THE GLASS MAN
OHIO
Just wondering what hoods or scoops will clear a new mopar crossram and holleys on a 67 satellite with a mega-block hemi. Will also need to use some form of air cleaners too. Am open to suggestions on some low profile ones.
This is Larry @ Sled City Fiberglass. What I tell my customers is, get your carbs bolted on and then get the air cleaner base that goes down over the base , possibly Moroso, cut the hole in the hood and see how far those cleaners come through. Then get a good bolt on scoop, which Sled City makes----we also make your hood. We race that same combo but with no air cleaners.
[Re: THE GLASS MAN]
#1561119
01/09/14 07:12 PM
01/09/14 07:12 PM
Posts: 188 MD.
vttm
MD.
Not sure I'll be able to use one or that that's the what I want yet but do you guys make a 66-67 hemi b-body scoop.
[Re: vttm]
#1561120
01/09/14 07:40 PM
01/09/14 07:40 PM
Posts: 81 VA
VPofGreen
VA
He does make the standard RO/WO scoop. http://www.sledcityevents.com/fiberglass/I would like to ask an additional question of Larry the Glassman. Could you do that RO scoop in a 5 1/4 inch (or close) version? thanks Mike
