2 1/2 or 3" Exhaust in Stainless or Aluminumized?
#1560917
01/08/14 04:54 PM
01/08/14 04:54 PM
Posts: 1,520 West Palm Beach, Florida
Copper Dart
I'm almost ready for the Exhaust system and wonder what are the Pro's and Con's of both 2.5" or 3.0" and Stainless or Aluminized pipe. I found a shop that will do an all Custom Mandrel bent system with a "X" pipe for my '70 Swinger with a Mild 440, Try-Y's 727, Mini tubbed. I would think the 3" is an overkill but I may grow into it later. What say you? Thanks.
Common sense, the least common of all the senses. Mom.
For fear of ridicule, society stifles creativity. Ricky Valdes
Re: 2 1/2 or 3" Exhaust in Stainless or Aluminumized?
[Re: Copper Dart]
#1560922
01/08/14 06:04 PM
01/08/14 06:04 PM
RSNOMO
Moparts Torchbearer
Moparts Torchbearer
heat containment
Which is why I went aluminized...
[Re: RSNOMO]
#1560923
01/08/14 06:09 PM
01/08/14 06:09 PM
Posts: 21,073 Niles , Ohio
therocks
Niles , Ohio
3 inch stainless with mufflers on the kids 62 300.All mandrel and the guy charged him like 325 for all.That was about 12 years ago.Rocky
Chrysler Firepower
[Re: therocks]
#1560924
01/08/14 06:29 PM
01/08/14 06:29 PM
Copper Dart
Rocky, I've gotten estimates for around $1,600. Using the 2.5" aluminized pipe only lowers the costs about $300. The expense is in the labor and custom Mandrel bending. The system is installed from header flange to bumper with those special clamps, "X" pipe, Custom Stainless mufflers and fully serviceable too. Sounds like everything else on this build. OVER BUDGET!
[Re: can.al]
#1560927
01/08/14 09:54 PM
01/08/14 09:54 PM
Posts: 22,696 Bitopia
jcc
Bitopia
I seldom inner purge when welding SS tube, but my experience is it often forms nodules/burrs inside when tig welded, and likely not reachable or visible when welded on long tailpipe sections, and for max flow, that bothers me, FWIW.
[Re: can.al]
#1560928
01/08/14 09:57 PM
01/08/14 09:57 PM
therocks
Niles , Ohio
That sounds like a ton of cash.The guy that did my kids did it at the time from the manifolds back.He even supplied the SS mufflers.My kid did cut them when he installed the custom headers he bought used.Another guy here was going to make him a custom set of headers for 1200 bucks.I didnt think that was a lot.You can buy TTIs exhasust for around 700 IIRC.Rocky
Chrysler Firepower
[Re: 340SHORTY]
#1560930
01/08/14 11:34 PM
01/08/14 11:34 PM
Copper Dart
Thanks for your comments. Do TTI's fit on a spring relocated to the frame rail and narrowed rear set up? I need to look into them, I don't think my mods are anything radical that would affect exhaust routing. The only issue might be attaching the TTI's to the Schumacher Tri Y's. ? As far as issues with the welds, I don't think there will be many welds, most of the connections will be those flat band clamps at service locations. Nothing is in stone yet.
[Re: Copper Dart]
#1560931
01/08/14 11:43 PM
01/08/14 11:43 PM
Copper Dart
Just read on TTI's site foot note #57 Leaf-Springs relocated MUST USE FUEL CELL..........
[Re: Copper Dart]
#1560932
01/09/14 12:52 AM
01/09/14 12:52 AM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
2.5 is plenty.The F.A.S.T. series cars use 2.5 and they are in the 10 second bracket.
[Re: Cab_Burge]
#1560935
01/09/14 10:11 AM
01/09/14 10:11 AM
Posts: 4,314 Prospect, PA
BSB67
Prospect, PA
So Cab, do you really think that in your example of going from 109 to 117 mph was because of the restriction of a perfectly good 2 1/2 exhaust system and nothing else? What is that, like 80 hp on a pretty mild motor? I have more than one example of going from a 2 1/4 compression bent system to open headers that netted 2 mph in 12 second cars. Obviously your experience is your experience, but logic suggests to me that possibly something else was at play in your example.
