71 challenger convertible #1560881
01/08/14 04:34 PM
01/08/14 04:34 PM
illinois
scottyb1955 Offline OP
illinois
I bought two mopars just a few months ago and this being the first mopars I have owned I am learning a lot but this has me stumped, I bought a factory 69 hemi road runner and this 71 big block challenger convertible I have quite a few diehard mopar friends and they were confused to. dose anyone know why ther would be two seat catches I looked in the roadrunner and it only had one set I didn't know if it was common for E body's to have this's?
Re: 71 challenger convertible [Re: scottyb1955] #1560882
01/08/14 04:41 PM
01/08/14 04:41 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Did the converts have the catch in a different location? Maybe one was install wrong at the factory and a new one was welded on in the correct place.
Re: 71 challenger convertible [Re: burdar] #1560883
01/08/14 04:44 PM
01/08/14 04:44 PM
illinois
illinois
They are on both driver and passenger side
Re: 71 challenger convertible [Re: scottyb1955] #1560884
01/08/14 04:57 PM
01/08/14 04:57 PM
Andrewh Offline
Andrewh  Offline
which one does it latch to?
front one looks odd, is that seam sealer or a blob of weld?
Re: 71 challenger convertible [Re: Andrewh] #1560885
01/08/14 05:11 PM
01/08/14 05:11 PM
Horsham, Pa.
Finoke Offline
Finoke  Offline
Horsham, Pa.
My 71 chally vert also had two sets. I'm not sure why
Re: 71 challenger convertible [Re: Andrewh] #1560886
01/08/14 05:12 PM
01/08/14 05:12 PM
illinois
illinois
The seat latches on the back ones, it's seam sealer in the pick not weld they are spot welded and looks to be factory
Re: 71 challenger convertible [Re: scottyb1955] #1560887
01/08/14 05:34 PM
01/08/14 05:34 PM
Horsham, Pa.
Finoke Offline
Finoke  Offline
Horsham, Pa.
I will check my 70 vert when I get home. I'm positive my 71 was like that. I will try to find a picture.
Re: 71 challenger convertible [Re: scottyb1955] #1560888
01/08/14 07:29 PM
01/08/14 07:29 PM
California, USA
filmsurgeon Offline
filmsurgeon  Offline
California, USA
Same on my '70 Challenger convertible. Also don't know why there are two.
Re: 71 challenger convertible [Re: filmsurgeon] #1560889
01/08/14 07:39 PM
01/08/14 07:39 PM
Boston, MA
crocha617 Online content
crocha617  Online Content
Boston, MA
I've had a bunch of convertibles and I can't remember any of them having 2 catches on each side. I'll have to check my photos and my current car.
Re: 71 challenger convertible [Re: crocha617] #1560890
01/08/14 08:14 PM
01/08/14 08:14 PM
Virginia
larry4406 Offline
larry4406  Offline
Virginia
My 71 barracuda vert does not have that. Only one seat catch per side.
I recall seeing double seat catches before either here or on cuda-challerger.com
Re: 71 challenger convertible [Re: crocha617] #1560891
01/08/14 08:16 PM
01/08/14 08:16 PM
Maple Valley, WA
70mopes Offline
70mopes  Offline
Maple Valley, WA
My '70 cuda convert (SPD 4/10) only has one on each side.
Re: 71 challenger convertible [Re: 70mopes] #1560892
01/08/14 08:24 PM
01/08/14 08:24 PM
central P.A.
HEMIDOG 70 Offline
HEMIDOG 70  Offline
central P.A.
My 70 Challenger vert has two latches on each side.My car was built in Sept 69 if that matters.
Re: 71 challenger convertible [Re: HEMIDOG 70] #1560893
01/08/14 08:27 PM
01/08/14 08:27 PM
California, USA
filmsurgeon Offline
filmsurgeon  Offline
California, USA
Mine was built 11/14/69.
Re: 71 challenger convertible [Re: filmsurgeon] #1560894
01/08/14 08:51 PM
01/08/14 08:51 PM
RI Deep in the rust belt
chargervert Offline
chargervert  Offline
All three of the Challenger convertibles I have owned were like that. One is a 71,the other two are 70s. The two Barracuda convertibles only had one catch per side. One was a 70 the other was a 71. I'm guessing it may be because the Challenger has a two inch longer wheelbase than the Cuda,right in that area. Maybe all the pans were made to fit Cuda's,and the second bracket was added when it was used for a Challenger.
70 Charger R/T SE 472 Hemi 70 Charger R/T convertible 70 Charger R/T V Code Sixpack 69 Charger R/T SE Sunroofcar 68 Charger 383 68 Charger 318 71 Charger R/T 70 Challenger convertible 71 Challenger convertible 71 Cuda 340 09 Challenger R/T Classic
Re: 71 challenger convertible [Re: chargervert] #1560895
01/08/14 09:30 PM
01/08/14 09:30 PM
Wisconsin
Stewpar Offline
Stewpar  Offline
Wisconsin
Compare notes on what plant the cars were built at........
Admiration For Multiple Carburetor Vehicles...
Re: 71 challenger convertible [Re: Stewpar] #1560896
01/08/14 10:21 PM
01/08/14 10:21 PM
central P.A.
HEMIDOG 70 Offline
HEMIDOG 70  Offline
central P.A.
Hamtramck 9-30-69 for mine.
Re: 71 challenger convertible [Re: scottyb1955] #1560897
01/08/14 10:36 PM
01/08/14 10:36 PM
California
biggE Offline
biggE  Offline
California
I believe that in the original position when the rear seat bottom was installed that there was a gap between the seat bottom and back that was large enough to see the rear floor pan. By mounting the seat bottom back further the problem was eliminated.
Re: 71 challenger convertible [Re: biggE] #1560898
01/08/14 10:59 PM
01/08/14 10:59 PM
chargervert Offline
chargervert  Offline
If that was the case,then Cuda convertibles would have the same double bracket too. They use the same convertible top frame as the Challenger,and the seat is in the same position. I still believe it is because there is a two inch wheelbase difference. The Cuda has a 108 inch wheelbase,and the Challenger has a 110 inch wheelbase. The difference is found between the rear of the door jamb and the rear wheelwell. If you look at the photos of the Challenger convertibles double seat bracket,it is about two inches difference.
Re: 71 challenger convertible [Re: chargervert] #1560899
01/08/14 11:09 PM
01/08/14 11:09 PM
Toronto (YYZ) Ontario
YYZ Offline
YYZ  Offline
My '71 Challenger ragtops had the double clips
'71 340 rag - Dec '70 SPD
Re: 71 challenger convertible [Re: YYZ] #1560900
01/09/14 03:56 AM
01/09/14 03:56 AM
P
PasiR Offline
PasiR  Offline
P
One per side.
GranCoupe 8-69 built.
