Valve Job Question #1560852
01/08/14 03:18 PM
01/08/14 03:18 PM
south central nebraska
GI Moparman Offline OP
I just dropped my heads off at the machine shop for my hemi and asked some questions on my valve job because a retired machinest who stopped by my shop took a peak at them and said that the contact area for intake valve to seat isn't wide enough. He said that on his performance engines he set them at close to .100 on the 45. My machinest says he puts the intakes at .060. So what do you guys do?
Re: Valve Job Question [Re: GI Moparman] #1560853
01/08/14 03:28 PM
01/08/14 03:28 PM
Union grove,wi
cj391 Offline
cj391  Offline
Union grove,wi
I'm far from a professional. .060 sounds a lot better to me though.
Re: Valve Job Question [Re: GI Moparman] #1560854
01/08/14 03:41 PM
01/08/14 03:41 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
As I understand it, the wider margin flows less but last longer like in a street build and the narrower margin flows best but doesn`t last as long. And of course multi angles are favored for flow which =more power.............
Re: Valve Job Question [Re: Thumperdart] #1560855
01/08/14 04:02 PM
01/08/14 04:02 PM
The guy doing my heads does a 3 angle on everything. Grandmas 4cyl or grain truck. Just checkin on width. I agreed with the way he explained it for how wide he makes them. Thanks for the input.
Re: Valve Job Question [Re: GI Moparman] #1560856
01/08/14 04:07 PM
01/08/14 04:07 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I`d say he`s leaving power on the table cos a few I know do as many as 5 angles and even heard of more but I`m no machinest so,..........
Re: Valve Job Question [Re: GI Moparman] #1560857
01/08/14 04:34 PM
01/08/14 04:34 PM
It depends on the heads, wedge or Hemi, on which works best I agree with Dominc on the longevity of the V.J., I had to learn that the hard way To narrow doesn't last very long at all on the street, .060 on a wedge head might last 1200 miles, maybe less .080 will last on the street, .100 on the exhaust seats and valves will transfer more heat to the seats than .080 will
Re: Valve Job Question [Re: Cab_Burge] #1560858
01/08/14 04:38 PM
01/08/14 04:38 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
When Jason installed my 2.19 intakes he gave me a multi-angle racing v-job which he said should go 20,000 miles no problem..........
Re: Valve Job Question [Re: Thumperdart] #1560859
01/08/14 04:45 PM
01/08/14 04:45 PM
This question is in regards to the hemi heads off of old smoky. Street car. Prob never see the track.
Re: Valve Job Question [Re: GI Moparman] #1560860
01/08/14 05:02 PM
01/08/14 05:02 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Whatever seals and last the longest I guess...........
Re: Valve Job Question [Re: GI Moparman] #1560861
01/08/14 05:20 PM
01/08/14 05:20 PM
S. Il. U.S.A.
5spdcuda Offline
5spdcuda  Offline
S. Il. U.S.A.
Just my opinion, but when it comes to my own cars durability and reliability trump ultimate power every time. Actually even when we're talking about race cars most of people on this board when they talk about race cars are referring to drag racing bracket cars. In bracket racing winning usually depends more on consistency, predictability, and reliability than it does on being the fastest car on the track. High performance always involves a trade off between maximum possible power and durability. Even in a "heads up" environment eg. Pro Stock, Nascar, Indy Car etc. you have to be able to go rounds or make it to the final lap to win. Bottom line go with a wider seat for street use and longevity.
Re: Valve Job Question [Re: 5spdcuda] #1560862
01/08/14 05:35 PM
01/08/14 05:35 PM
So if I'm understanding it correctly, go 080 on intake and 100 on exhaust. I'm looking for making it live on the street. To much money in this thing to go for every hp.
Re: Valve Job Question [Re: GI Moparman] #1560863
01/08/14 05:51 PM
01/08/14 05:51 PM
Delray beach, Florida
P
Performance Only Offline
P
This whole scenario based only on the width of the seat contact area is misleading at best IMO. The width is important, but seat concentricity, valve concentricity and the location where that 45 degree angle intersects the valve is way more important than just the width. There's no reason a .060 wide seat won't live a long life on a high performance street engine as long as the location and concentricity are what they should be.
Old worn out valve grinders, worn out seat/guide machines or stones and holders and even hurried machinists would be your worst enemy. good equipment and attention to detail will net great results and great longevity. I've used .040 wide seats on street/strip engines and we don't have any problems with longevity. Your basic 250 HP grocery getter would get a wide 45 angle and last 100,000 miles, a .060 seat done right will live as long as the rest of a good performance build if done right.
If in doubt, use some ultra fine lapping compound and only two or three twists of the stick and then look to see the where the gray line is located on the valve and if it goes all the way around the seat at the same width. If it does, you're fine, if it doesn't, have them fix it so it does.
machine shop owner and engine builder
Re: Valve Job Question [Re: Performance Only] #1560864
01/08/14 06:18 PM
01/08/14 06:18 PM
SoCal
Brian Hafliger Offline
SoCal
.060 is fine!
Brian Hafliger
Re: Valve Job Question [Re: Brian Hafliger] #1560865
01/08/14 06:25 PM
01/08/14 06:25 PM
P
P
.060 is fine!
That's probably what I should've said and saved myself a bunch of typing.
Re: Valve Job Question [Re: Performance Only] #1560866
01/08/14 08:42 PM
01/08/14 08:42 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I have always made my intakes about .060 and never no problems. I like the exh a bit wider about .080 to disipate the heat fast enough but to wide is more chance of carbon building on the seat over the years and more area to keep sealed as the miles get put on. Ron
Re: Valve Job Question [Re: 383man] #1560867
01/13/14 12:14 AM
01/13/14 12:14 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
as two points of reference.....
i remember being in Bartons shop many years ago(late-80's) when he was still up in the Montreal area, and saw some SS/AA heads he was working on there.
the intake valve seats were just a very, very thin pencil line.....probably around .015" wide at most, right on the very edge of the valve.
on the other end of the spectrum, that old SBC Pro Stock engine book by Grumpy Jenkins specified the intake seat width to be .100" wide......and that was for a true max effort application.
so whats the right width seat???
its just another example of the many, many things that are engine related that fall into the "it depends" catagory.
