Re: How to tell if car is coupe or 2 door sedan model
[Re: frank]
#156058
11/24/08 07:00 PM
11/24/08 07:00 PM
3RD AND 4th digits of the vin 21 is a 2 dr sedan 23 is a 2 dr hardtop 27 is a convertible 29 is a 2dr sports hardtop(baracuda) I hope this helps
[Re: frank]
#156063
11/24/08 07:43 PM
11/24/08 07:43 PM
Posts: 169 Maine
itali83
Maine
Can't get any easier than this. Sedan = pop out rear windows Hardtop/coupe = roll down rear windows
'68 Roadrunner Built 440/727 4:10 filled 8 3/4 in the process of a ground up restification
[Re: itali83]
#156064
11/24/08 08:24 PM
11/24/08 08:24 PM
Posts: 4,999 North Pole,New York
formula_s
North Pole,New York
The rear windows in my 75 Coronet hardtop, WH23 didn't roll down.
[Re: formula_s]
#156065
11/24/08 08:39 PM
11/24/08 08:39 PM
RapidRobert
I''m still confused ![](/ubbthreads/images/graemlins/frown.gif) Are coupes/sedan the same(both have a post)
[Re: itali83]
#156068
11/24/08 09:30 PM
11/24/08 09:30 PM
Posts: 10,234 Someplace you aren't
SomeCarGuy
"Post coupe" is usually what I hear, and have said myself coupe for cars with a post for years. Windows pop out. RM21
Hardtop has no pillar, roll down windows. RM23 Have seen/heard it called pillarless hardtop.
[Re: Rhinodart]
#156071
11/25/08 09:08 AM
11/25/08 09:08 AM
Posts: 12,494 Western Colorado High Desert
moparmarks
It depends on the manufaturer, but I have always thought a sedan and a post car were the same thing, and a hardtop and a coupe were the same!
![](/ubbthreads/images/graemlins/iagree.gif)
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
[Re: Junky]
#156073
11/25/08 10:59 AM
11/25/08 10:59 AM
Posts: 12,481 Chino Valley
RodStRace
Chino Valley
![](/ubbthreads/images/graemlins/iagree.gif) Post = sedan roll all the windows sown and you can sweep your arm from the windshield to the rear roof post = hardtop. The problem is that the automakers built different cars over the years, so the rules got blurred. In your specific case (1969 B body), the VIN will tell you what you have and will be easier to pass along to year one for ordering. ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: Junky]
#156074
11/25/08 11:05 AM
11/25/08 11:05 AM
Posts: 21,845 Kirkland, Washington
Pacnorthcuda
Growing up as a kid (I'm old) a 2 door with no post was a hardtop, 2 door with a post a coupe, 4 door with a post a sedan. 4 doors without a post was cool. Most everyone I know goes by this too.
I agree with this. Also the 4 door without a post can obviously be called a hardtop, or a "4 door hardtop" An example would be a Buick Electra 225.
Only problem is that there is no "2 door sedan" in the above definition, which many people would say in a post car, if the rear 1/4 windows roll down its a sedan, if they don't (or they just pop out) like a Volare/Aspen its a coupe, but thats kind of a fine distinction.
[Re: moparmarks]
#156075
11/25/08 11:33 AM
11/25/08 11:33 AM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
Not correct.... A hardtop has no B-Pillar. A Coupe has a B-Pillar (post).
The line between a 2-dr sedan (post) and a coupe gets blurry, I tend to differetiate between posts & coupes as: A coupe has almost no rear window (E body cudas & Challengers are coupes), while a post has a roll down or pop out, larger rear window (roadrunner)
One things for sure, there is no hard fast rule with coupes vs. posts vs. 2-dr Sedans. These are all basically the same.
