Upper steering column bearing and c clips?? #1560616
01/08/14 01:46 AM
01/08/14 01:46 AM
1969proDart Offline OP
Need help finding an upper bearing set for my 69 dart. If anyone knows where I can get a set new repro I don't care, let me know..Thanks
Re: Upper steering column bearing and c clips?? [Re: 1969proDart] #1560617
01/08/14 11:59 PM
01/08/14 11:59 PM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
This one? If you want the numbers off it, I can send them. In my experience, if you go to a bearing dealer, they can duplicate or cross reference the numbers.
Re: Upper steering column bearing and c clips?? [Re: kentj340] #1560618
01/09/14 12:03 AM
01/09/14 12:03 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
The C clip is standard hardware store stuff, but a bearing dealer should have them too.
Re: Upper steering column bearing and c clips?? [Re: kentj340] #1560619
01/09/14 12:36 AM
01/09/14 12:36 AM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
I picked my bearing up from an online Chrysler dealer, Monicatti Chrysler and just re-used the clips. I couldn't find it @ the online bearing stores, YMMV. HTH Steve
Re: Upper steering column bearing and c clips?? [Re: Skeptic] #1560620
01/09/14 01:36 PM
01/09/14 01:36 PM
mega parts sells the bearing and a clip set.
Re: Upper steering column bearing and c clips?? [Re: 1969proDart] #1560621
01/09/14 02:09 PM
01/09/14 02:09 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Pretty sure you can get the bearing from the dealer still.
Re: Upper steering column bearing and c clips?? [Re: kentj340] #1560622
01/10/14 01:07 AM
01/10/14 01:07 AM
Exactly the one I need! Mine is shot. I want new c clips also. Just in case.
Re: Upper steering column bearing and c clips?? [Re: 1969proDart] #1560623
01/11/14 03:16 AM
01/11/14 03:16 AM
Partridge, KY
Hoop Offline
Hoop  Offline
Partridge, KY
Just wounding, How can you tell when its shot!
Re: Upper steering column bearing and c clips?? [Re: Hoop] #1560624
01/11/14 03:32 PM
01/11/14 03:32 PM
sweden
cuda-sweden Offline
cuda-sweden  Offline
sweden
you will probably hear it scream in pain..
Re: Upper steering column bearing and c clips?? [Re: cuda-sweden] #1560625
01/11/14 03:34 PM
01/11/14 03:34 PM
Candler,NC / Myrtle Beach, SC
JDMopar Offline
JDMopar  Offline
That's true...but wouldn't it do the same thing if it had been stabbed?
Re: Upper steering column bearing and c clips?? [Re: Hoop] #1560626
01/12/14 02:02 PM
01/12/14 02:02 PM
Cincinnati, Ohio
Cincinnati, Ohio
It'll be real rough or be missing the 4 balls that's in it. That's all it has is like 4 ball bearings so corrosion and such can cause it to fall apart pretty easy, it's a really cheap bearing.
Re: Upper steering column bearing and c clips?? [Re: Challenger 1] #1560627
01/12/14 03:26 PM
01/12/14 03:26 PM
md
mopars4ever Offline
mopars4ever  Offline
md
not cheap for a such a little bearing. around $30 at the dealer.
Re: Upper steering column bearing and c clips?? [Re: mopars4ever] #1560628
01/12/14 03:28 PM
01/12/14 03:28 PM
md
mopars4ever Offline
mopars4ever  Offline
md
mega showed the clips but no bearing.
http://www.megapartsusa.com/proddetail.asp?prod=199-DR055
Re: Upper steering column bearing and c clips?? [Re: mopars4ever] #1560629
01/13/14 12:27 AM
01/13/14 12:27 AM
moparx Offline
moparx  Offline
most times you can get c-clips and snaprings at your local ace hardware. cost : about $2.50 in a 3 pack or about a buck when bought singularly.
Re: Upper steering column bearing and c clips?? [Re: mopars4ever] #1560630
01/13/14 04:36 AM
01/13/14 04:36 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Hey guys, that's why I volunteered to give you the numbers off it so you could go to a bearing dealer and buy the exact same thing or better for $7.52 plus tax...
Re: Upper steering column bearing and c clips?? [Re: kentj340] #1560631
01/13/14 01:32 PM
01/13/14 01:32 PM
Northeast MA
Charger446 Offline
Charger446  Offline
Northeast MA
Id be interested in the part number. Need one for my 68 Charger, I believe its the same. Mine isnt making any noise, but it wiggles a bit on the shaft so Im assuming its toast...
Re: Upper steering column bearing and c clips?? [Re: Charger446] #1560632
01/14/14 09:37 PM
01/14/14 09:37 PM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
I was just jerking your chain about the $7.52 price tag - have no idea what they cost generic-wise. I'll post the numbers when I get back to my Mopar man cave in a few days.
Re: Upper steering column bearing and c clips?? [Re: kentj340] #1560633
01/15/14 04:11 PM
01/15/14 04:11 PM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Sorry guys, mission failure - tried but could not find a generic bearing for the upper steering column. In 1969 this bearing, originally PN 2925491, fit all cars exept tilt and telescopic. Maybe the same for some other years too.
What makes this ultra low-speed bearing too special to be generic looks to be that it is unsealed, too crude, too small, and too un-robust. Besides that, the outer race is mounted in a rubber insulator that makes this application unusual.
Starting with the 3/4" ID, the smallest OD I found for generic is 1-3/8", but this part is only 1-3/16". Also generics are thicker.
There are 12 balls in my original. Head scratcher - the rubber insulator has a mashed staple through it, maybe as an electrical conductor between the bearing and the mount?
