Rear end swap 7 1/4"-8 3/4" #1560308
01/07/14 05:29 AM
01/07/14 05:29 AM
P
PasiR Offline OP
PasiR  Offline OP
P
Can I use 7 1/4" drum backing plates for 8 3/4" housing?
Re: Rear end swap 7 1/4"-8 3/4" [Re: PasiR] #1560309
01/07/14 01:52 PM
01/07/14 01:52 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
As long as you have the parts in hand you might as well see if they bolt up. That seems to be the way a lot of us have found how all this stuff goes together. Chrysler probably used the same backing plates based on drum size for 7.25" and 8.75" stuff. Let us know.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: Rear end swap 7 1/4"-8 3/4" [Re: PasiR] #1560310
01/07/14 04:23 PM
01/07/14 04:23 PM
dogdays Offline
dogdays  Offline
except the A-body specific stuff?
R.
Re: Rear end swap 7 1/4"-8 3/4" [Re: dogdays] #1560311
01/07/14 04:30 PM
01/07/14 04:30 PM
Inver Grove Heights MN
74RR Offline
74RR  Offline
I thought the 7 1/4 plates wouldn't bolt up to a 8 1/4 or 8 3/4" rear?
Re: Rear end swap 7 1/4"-8 3/4" [Re: 74RR] #1560312
01/07/14 04:52 PM
01/07/14 04:52 PM
BDW Online content
BDW  Online Content
Re: Rear end swap 7 1/4"-8 3/4" [Re: BDW] #1560313
01/07/14 08:11 PM
01/07/14 08:11 PM
the 7&1/4 & (A body) 8&3/4 both use 1&3/4" wide shoes & as you know the shoe width has to match the drum width & requires a backing plate offset matched to them but I was thinking the 8&3/4 outer seal retainer & therefore the housing flange had 5 studs/nuts & only 4 on the 7&1/4 but I ain't sure on that. something was diferent iirc & man I was just over there earlier today but had other business on my mind
Re: Rear end swap 7 1/4"-8 3/4" [Re: RapidRobert] #1560314
01/08/14 05:27 AM
01/08/14 05:27 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
The '73 and up BBP 10" brakes off an A body 7-1/4 will bolt right on an 8-3/4 as long as the bearing to flange spacing is correct.
Re: Rear end swap 7 1/4"-8 3/4" [Re: slantzilla] #1560315
01/08/14 12:47 PM
01/08/14 12:47 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I found out B-Body backing plates are different than A-Body after I got a set back from a powder coater and he sent me the wrong plates back. Different width shoes as said above, the areas where the shoes ride is higher on A-Body plates.
JB Rhinehart, Realist
A-Body's RULE!
