70 cuda turn signal housing tape? #1560132
01/06/14 10:53 PM
01/06/14 10:53 PM
california santa clarita
moparpete22 Offline OP
what type of black tape should i use on the turn signal lenses that go in the grill? reflective tape? or just some standard blk paper type tape? thanks for the help
Re: 70 cuda turn signal housing tape? [Re: moparpete22] #1560133
01/06/14 11:19 PM
01/06/14 11:19 PM
SE PA.
Q
QuickBpBp Offline
QuickBpBp  Offline
Q
SE PA.
BE & A sells the correct pieces to put on your lenses....
Re: 70 cuda turn signal housing tape? [Re: QuickBpBp] #1560134
01/07/14 04:09 PM
01/07/14 04:09 PM
Hi. Great thank you very much for the info. pete
