This Crower Cam anything worth using? M-300-H
#1560083
01/06/14 09:03 PM
01/06/14 09:03 PM
Posts: 1,562 Manistee, Michigan.
High Impact
Manistee, Michigan.
Going thru stuff at the shop today and I found another old cam in an old Box. Its a Crower M-300-H and appears to be dirty but was protected somewhat with a greasy film. Is is something for the scrap pile? What engine would it be good for? 440??
Its for a Big Block mopar....should have said that..
Re: This Crower Cam anything worth using? M-300-H
[Re: High Impact]
#1560089
01/07/14 02:23 AM
01/07/14 02:23 AM
Posts: 304 Portland, Oregon
Digger73
Portland, Oregon
Years ago I ran an M-280-H in my 383. It was 280*duration on the intake and .484 lift. Hydrolic lifters. It had a real nice lope at idle and came on strong in the mid range. It worked great in my 68 Roadrunner with a 4spd. I would imagine your cam is more lift and obviously more duration. The old catalog I have has the replacement to the Monarch series and lists a 300H cam with 300* int. 310* exh. with 238* and 246* @.050. Lift is .530" int and .549" exh. Hope this helps. Good luck.
Digger73 (Mike)
I live with fear everyday but, sometimes she lets me race!
[Re: High Impact]
#1560091
01/07/14 05:10 PM
01/07/14 05:10 PM
Posts: 9,872 Weddington, N.C.
Streetwize
Weddington, N.C.
That monarch is a good old school cam for a 440 dual plane 9.5:1 a little headwork and headers. Should be 108 LDA and I put it in +3 at 105.
Was replaced by the Crower HDP (hydraulic dual pattern-asymmetrical) series in the mid late 80's (IIRC) that were a little quicker off the ramp but really didn't make any more power. What you have is a good one in between a 484 and 509 purple shaft like the old 30306 Lunati but with a choppier (nastier sounding) idle and a bit higher rev potential than the 509, whatch your P/V clearence if you don't have valve reliefs.
