Re: Vacuum pump?? [Re: reknapp52] #1559512
01/12/14 02:26 PM
01/12/14 02:26 PM
MR_P_BODY Offline
MR_P_BODY  Offline
FWIW--I have heard that for a vacuum pump to be effective, you need to install your crankshaft oil seals backwards?
Only if you go above a certain point.. a lot of the
seal companies say above about 14" to 16"hg but if
the seal surface is weak then that point would be lower
Re: Vacuum pump?? [Re: MR_P_BODY] #1559513
01/12/14 04:58 PM
01/12/14 04:58 PM
A shed in England
Tig Offline
Tig  Offline
A shed in England
Low tension, 0.043 ring package here with a 4 vane Moroso, 12 In/Hg max, maybe worth 0.05 on our combo IIRC.
Re: Vacuum pump?? [Re: fishy340] #1559514
01/14/14 11:20 AM
01/14/14 11:20 AM
an8sec70cuda Online content
an8sec70cuda  Online Content
We didnt see much on the dyno,but i NEVER had any oil leaks ever
They do seem to help w/ oil leaks.
CHIP
'06 GMC 2500HD LBZ Duramax
