Re: Vacuum pump??
[Re: bobs69]
#1559495
01/05/14 11:48 PM
01/05/14 11:48 PM
Posts: 740 WA
JD Dart
WA
No gain even at 16 inches. The motor didn't use oil with low tension rings and the oil stayed cleaner. I would suggest not running that much main bearings don't look good oil psi drops too much with that much vacuum.
best so far 8.53 @ 158.59 MPH 60'1.240
Re: Vacuum pump??
[Re: bobs69]
#1559496
01/06/14 12:02 AM
01/06/14 12:02 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Did you gain anything when you added a vacuum pump? Is it worth the money? My car goes 6.0's without a vacuum pump will I gain anything with one? Thanks
Most low tension rings like a vac pump but any help evacuating the pan only helps.. to my understanding you dont want to go above 14"hg
Re: Vacuum pump??
[Re: MR_P_BODY]
#1559497
01/06/14 09:38 AM
01/06/14 09:38 AM
Posts: 10,384 Upstate NY
Bigcube
Upstate NY
I tested my motor with and without the pump. In my combo it was worth about 25 hp.
Re: Vacuum pump??
[Re: bobs69]
#1559500
01/07/14 01:59 PM
01/07/14 01:59 PM
Posts: 13,377 Marion, South Carolina [><]
an8sec70cuda
Didn't test on the dyno, but a vacuum pump didn't make any difference at the track on my cuda. It has low tension rings too. If you do buy one, do NOT get an Aerospace pump.
Re: Vacuum pump??
[Re: an8sec70cuda]
#1559501
01/07/14 02:50 PM
01/07/14 02:50 PM
Posts: 142 illinois
evenflow
illinois
why not aerospace?
Re: Vacuum pump??
[Re: evenflow]
#1559502
01/07/14 02:59 PM
01/07/14 02:59 PM
MR_P_BODY
why not aerospace?
They dont create as much vac as other brands
Re: Vacuum pump??
[Re: MR_P_BODY]
#1559504
01/07/14 03:06 PM
01/07/14 03:06 PM
an8sec70cuda
why not aerospace?
Mine makes about 8-10" at WOT, which may be why I've never seen any performance increase. I've had 2 pumps fail and problems w/ the drive mandrels too. Much better w/ the CV products drive mandrel now. When this pump dies, I'll put a Moroso on it. Of course I do street drive mine, whish isn't recommended, but I don't know anyone w/ an Aerospace pump that likes it...even on a race only car.
Re: Vacuum pump??
[Re: Thumperdart]
#1559505
01/07/14 03:14 PM
01/07/14 03:14 PM
MR_P_BODY
why not aerospace?
How much is "not enuff" cos too much has ill affects I understand.........
If you can create vac at lower RPMs then have a vac relieve its better... I dont run a vac pump on my W-9 because its a dry sump and that pumps pulls 12"hg and thats close enough for me
Re: Vacuum pump??
[Re: MR_P_BODY]
#1559506
01/11/14 11:32 PM
01/11/14 11:32 PM
Posts: 6,147 Melbourne , Australia
LA360
What ring dimensions are you running in your engine? Thinner rings will see more gains. A 5/64" or 1/16" rings won't see the gains that a 0.027" ring will.
Alan Jones
Re: Vacuum pump??
[Re: an8sec70cuda]
#1559507
01/11/14 11:44 PM
01/11/14 11:44 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
I have a moroso 3 vane and can only get 10-12 inches. I heard the four vanes are much better. But I have gotten rave reviews about the GZ pumps.
Brett Miller W9 cnc'd heads STR Chassis fabraction
Re: Vacuum pump??
[Re: LA360]
#1559508
01/12/14 12:25 AM
01/12/14 12:25 AM
MR_P_BODY
Mine is a .043 ring set with low tension oil
Re: Vacuum pump??
[Re: bobs69]
#1559509
01/12/14 12:11 PM
01/12/14 12:11 PM
Posts: 876 Arizona
PolyDart
Arizona
I was running 10.30s before adding a Moroso pump. I had been running crankcase evacuation through the header collectors prior to that. I saw no difference in ET or MPH after adding the pump. I was disappointed as I had hoped to at least drop a consistent .1 sec. I have a feeling that the power gain is ate up by the parasitic loss of running the pump itself. BTW, I am running low tension rings as well.
No dyno data, just track testing...
