At home alignment w/o fr tires, floor jacks at each LCA
#1559346
01/05/14 06:34 PM
01/05/14 06:34 PM
Posts: 6,840 The Swamp
Sixpak
The Swamp
I have one of those bubble level type of alignment gauges that fits over the spindle and sits on the face of the rotor with the grease cap removed. Curious if anyone has successfully done an alignment at home with the front wheels removed, and floor jacks under the lower control arms, just enough to get the wheels off, or perhaps lowered to be at the ride height with the tires on. We all know what a pain it is to get at the cam bolts (I'm dealing with a Duster body here, no access plates like a B or E body.) I'm wondering if anyone has tried to do an alignment this way, and then rechecked their measurements with the wheels back on - how much compressing the upper control arm bushings changed the settings, or possible ball joint play was taken up with the weight on the wheels. Will this get you in the ballpark, or better?
Re: At home alignment w/o fr tires, floor jacks at each LCA
[Re: BigBlockMopar]
#1559349
01/08/14 03:41 AM
01/08/14 03:41 AM
Posts: 171 Las Vegas, NV
chargerbr549
Las Vegas, NV
I have aligned several vehicles the same way as you described by setting the lca on jackstands and making sure to keep the ride heights the same front and rear as they were with tires on the front, it seemed like it worked ok although I never had them rechecked with tires on and a better alignment setup. Another option you might try is to get a Fasttrax alignment gauge they're not that expensive and you don't need turn tables or have the ground perfectly level, I have aligned several of my cars this way and had excellent results! Here's a short video of one being used, http://www.youtube.com/watch?v=ZwyfUXsXTV4&list=PL176CF5D77C6A3EC7
[Re: Sixpak]
#1559351
01/08/14 02:04 PM
01/08/14 02:04 PM
DemonDuster
I did similar on my Duster but used an angle finder on the brake rotor to set camber. An angle finder, straight edge, tape measure, string and 4 jack stands is how aligned my Duster 9 years ago. Handles great, wheel returns to center. and tire wear is even. I jacked up the lower control arms with small floor jacks. (Pulled torsion bars, shocks were removed and k frame at aprox. normal ride height)
[Re: jcc]
#1559354
01/08/14 11:46 PM
01/08/14 11:46 PM
Posts: 813 Ontario,Canada
brads70
Ontario,Canada
With this floor jack to LCA support solution, how are you measuring "ride height"? From spindle centerline to a point on the car or from the ground to a point on the car? I don't understand how you all are accounting for the difference in leverage on the TB by picking up the suspension at a much different point then the centerline of the tire/wheel to be used, or just don't care or think it doesn't matter enough?
I used blocks and shims to get the chassis at ride height ( without tbars installed) then using a jack set the lca/spindle at ride height. Then adjusted. It was very close when I checked it all out assembled and driving on an alignment machine at a front end shop.
