Tell Me About B Body Fuel Tank Vent Tubes #1559065
01/04/14 10:45 PM
01/04/14 10:45 PM
Spokane Valley, WA
Big Bad Bee Offline OP
Spokane Valley, WA
My 70 Bee has had the trunk floor removed and there's no gas tank vent tube. Is this the tube that loops in and out of the trunk floor? where does it route and where does it end? I'm curious if there is an accepted optional way of running the vent. My car has a new trunk floor with no holes in it. Pictures are appreciated.
I’m listening.
Re: Tell Me About B Body Fuel Tank Vent Tubes [Re: Big Bad Bee] #1559066
01/05/14 11:22 AM
01/05/14 11:22 AM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
this is for a 69 b-body. should be the same for at least 68-70.
Re: Tell Me About B Body Fuel Tank Vent Tubes [Re: Big Bad Bee] #1559067
01/05/14 11:58 AM
01/05/14 11:58 AM
Space Station #5
471Magnum Offline
471Magnum  Offline
Space Station #5
Two different systems in 70. One for CA and one for 49 states.
CA has a different tank with vents at the corners, and vapor separator mounted in the trunk, which in turn vented to the PCV system. And a bunch more hard lines and hoses connecting everything.
49 state vented direct to atmosphere.
Unfortunately, I don't have a diagram handy of either that would answer your question. I'd need to find my 70 FSM and scan that page. I'm sure someone else can beat me to posting it.
-Jim
I can fix it... my old man is a television repairman.
He's got the ultimate set of tools... I can fix it.
Currently Mopar-less
Re: Tell Me About B Body Fuel Tank Vent Tubes [Re: 471Magnum] #1559068
01/05/14 01:39 PM
01/05/14 01:39 PM
NB, Canada
moparfan53 Offline
moparfan53  Offline
NB, Canada
Here is pic from the '70 Plymouth FSM (don't have a Dodge one). I ASSuME it would be the same.
These are non CA emissions. If you want the CA pic, let me know.
- Alan
EDIT: just realized I took wrong pics from FSM, will correct shortly
EDIT: pic corrected. Looks the same as one posted above.
Re: Tell Me About B Body Fuel Tank Vent Tubes [Re: moparfan53] #1559069
01/05/14 02:17 PM
01/05/14 02:17 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
Here's a picture of a trunk floor, this is a 69 convertible.
Ron
Re: Tell Me About B Body Fuel Tank Vent Tubes [Re: RJS] #1559070
01/05/14 05:44 PM
01/05/14 05:44 PM
Spokane Valley, WA
Spokane Valley, WA
Ron
YES! Ron, Alan, this is just what I need! Now the other line appears to just dump directly out in front of the axle? Regardless, this is great stuff.
I’m listening.
Re: Tell Me About B Body Fuel Tank Vent Tubes [Re: Big Bad Bee] #1559071
01/06/14 01:18 AM
01/06/14 01:18 AM
IN
ahy Offline
ahy  Offline
IN
The factory vent systems worked. Other solutions like vented caps not so much. Suggest you put the vent system back to original. I believe inline tubes sells the vent tubes.
Re: Tell Me About B Body Fuel Tank Vent Tubes [Re: ahy] #1559072
01/06/14 01:49 AM
01/06/14 01:49 AM
Spokane Valley, WA
Spokane Valley, WA
I agree. I've found inline's product. Looks complete and not a bad price. Thanks for the help!
I’m listening.
Re: Tell Me About B Body Fuel Tank Vent Tubes [Re: Big Bad Bee] #1559073
01/06/14 08:40 PM
01/06/14 08:40 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
Ron
yes, it clips to the frame where the shock mount.
