E Body RIM Backspace #155898
11/24/08 02:16 PM
11/24/08 02:16 PM
Virginia Beach, Va
wtucker Offline OP
wtucker  Offline OP
Virginia Beach, Va
Has anyone run 295/50/15 on a 10" rim with 5" back space on a E-Body without any problems using stock springs?
Re: E Body RIM Backspace [Re: wtucker] #155899
11/24/08 08:28 PM
11/24/08 08:28 PM
Milwaukee
ToddP Offline
super street
ToddP  Offline
super street
Milwaukee
I don't think 5" backspacing will be enough.
To center a 10" rim between the wheel wells on my challenger, with stock width axle is 6.5" backspacing . This spacing will interfere with the stock 46" leaf spring spacing.
5" backspacing will clear the stock location leaf springs eaisly, but put the outside edge of the rim into the fender lip.
Re: E Body RIM Backspace [Re: ToddP] #155900
11/25/08 10:01 PM
11/25/08 10:01 PM
NotRussia
2
2fast4yourBrain Offline
Whack top Dodger
Whack top Dodger
2
NotRussia
Get a Dr. Diff 1" relocation kit.
w/a stock e-body rear end, you need 6" BS. W/a '66-'70 b-body rear end, 5" BS.
Re: E Body RIM Backspace [Re: 2fast4yourBrain] #155901
11/26/08 10:01 AM
11/26/08 10:01 AM
poplar bluff mo.
toplescuda Offline
I Whine
toplescuda  Offline
I Whine
poplar bluff mo.
we have 15x8 wheels with 5 inch of back spacing tires are 275x60,sx15 and we had to run a 1/4 spacer because both tires rubbed on the springs(all bone stock)
you will not get a 295 50 under the car unless you move the springs in some way or you raise the car and let it stick out some bit
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
Re: E Body RIM Backspace [Re: toplescuda] #155902
11/27/08 09:23 AM
11/27/08 09:23 AM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
15X8s with 4,5" backspacing. 295-50-15s.
