Dodge Techs 08 Ram Question Tranny #1558395
01/03/14 10:32 PM
01/03/14 10:32 PM
Anonymous OP
Anonymous OP
I just turned 100k on my 08 Hemi Ram--Love the truck--it has started a very slight shudder sometimes when put in reverse--it is not very noticable and does not do it all the time--seems to run just great but I can feel it and wondered what was going on. Would fluid and filter replacement help and if so do I need to adjust any bands? I have done dozens of band adjustments on 727's but what do I need to do while pan is off for fluid change? THANKS!!!!!
Re: Dodge Techs 08 Ram Question Tranny [Re: ] #1558396
01/04/14 12:07 PM
01/04/14 12:07 PM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
There are no adjustments to be made on the RFE model transmissions. I have had several with a disloged main filter seal on the pump that causes shuddering and slipping issues. They also are bad about cracking the main sump filter. This will also cause the same problem.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: Dodge Techs 08 Ram Question Tranny [Re: 71yelladustr] #1558397
01/04/14 11:59 PM
01/04/14 11:59 PM
Anonymous OP
Anonymous OP
Thanks man! It is time for filter and fluid swap anyway, appreciate the help
Re: Dodge Techs 08 Ram Question Tranny [Re: ] #1558398
01/06/14 10:46 AM
01/06/14 10:46 AM
Guitar Jones Offline
Make sure you replace both filters and only use the Mopar screw on filter.
