Intake manifold bottom plate
#1558383
01/03/14 10:29 PM
01/03/14 10:29 PM
Posts: 670 Third rock from the sun.
busboy
Just picked up an aluminum intake manifold that's missing that plate on the bottom. Everything is nice and clean, does this need to be replaced to use it? If so, can I just make something or are they sold?
Oh yeah, it's a hybrid.....it burns gas and tires!
Re: Intake manifold bottom plate
[Re: busboy]
#1558385
01/03/14 11:34 PM
01/03/14 11:34 PM
RapidRobert
the metal valley pan gasket is Felpro 1214 for 383/400 & Felpro 1215 for 440's. Has (4) .030" paper gaskets which you may or may not use or want to use. A guy on here sells thin ones (.015). Is your eng together & you picked up an alum intake for it?. People have reused the valley pans & if so I'd recommend a thin/even coat of Permatex #1 in the toothpaste like tube on both sides of each of the 8 port openings in the metal valley pan gasket. #1 is to mockup the intake/valley pan & see where on the slope of the "v" the intake resides as you even it up from side to side & the bolt hole alignment will tell you where you are at with that. block deck height/past milling/gasket thickness/head milling can put the width of the V & therefore where the manifold sits up at almost anywhere. If the width of the V will let you run the paper gaskets by all means do so & spray em with Permatex 99MA "high tack" the red stuff in the spray can. Goes on light/even & is extremely tacky & seals very well
[Re: busboy]
#1558388
01/04/14 03:55 AM
01/04/14 03:55 AM
Posts: 75,005 U.S.S.A.
JohnRR
U.S.S.A.
I'll ask instead of ASSuMEing ... Hemi, big block or smallblock ?
[Re: JohnRR]
#1558389
01/04/14 04:37 AM
01/04/14 04:37 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
And if small block... La or magnum? The stock magnums have an aluminum plate on the bottom too.
**Photobucket sucks**
[Re: JohnRR]
#1558390
01/04/14 10:59 AM
01/04/14 10:59 AM
busboy
Sorry guys, should have mentioned it, LA small block(340). I am using a lifter valley plate so I think I should be alright without the one on the bottom of the intake??
[Re: Michael Ecks]
#1558393
01/04/14 12:02 PM
01/04/14 12:02 PM
busboy
Ok thanks. This is an original aluminum six pack intake so the rivet holes are there but sounds like the valley baffle will do the trick.
