Wiper Linkage Question #1558376
01/03/14 09:43 PM
01/03/14 09:43 PM
North Carolina
cjskotni Offline OP
cjskotni  Offline OP
North Carolina
I am trying to put my linkage back together on my 73 Charger and now I am second guessing myself.
On the driver's side pivot, which ball joint goes to which linkage? I had the ball joint facing down connected to the motor linkage and the ball joint facing up connected to the rod that joins the two pivots. Was this correct?
Thanks!
Re: Wiper Linkage Question [Re: cjskotni] #1558377
01/03/14 11:27 PM
01/03/14 11:27 PM
morrisville, pa
skajm Offline
skajm  Offline
morrisville, pa
I do not know your answer, but when you get the linkage all together do not put the wipers on until you ran the motorand stop it. A buddy put it all together and wiped his hood (not a happy man). I put a tape flag to see if it parked right.
