Bought a new overdrive unit and it won't go on!
#1557956
01/02/14 07:34 PM
01/02/14 07:34 PM
Posts: 43,590 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
Found out that the overdrive unit on my 04 48RE had a cracked case and was leaking fluid, plus it quit working again for the third time, so I bought a new complete unit from Chrylser. I go to put it in and it won't go all the way in, seems that the planetaries might have moved and the splines will not engage. Talked with a couple people and they say I need to remove the large wave washer, take the clutches and plantetaries out, then re-align the planetaries, so they will slip over the splines in the output shaft of the trans. They also say that it may take a couple times before it will work. Anyone ever do this? Is there a special tool needed and a press I assume to remove the wave washer?
JB Rhinehart, Realist
A-Body's RULE!
Re: Bought a new overdrive unit and it won't go on!
[Re: redraptor]
#1557958
01/02/14 11:22 PM
01/02/14 11:22 PM
Rhinodart
Rhinotruck
Rhinotruck
Yep, watched the video and that is what it is, two of the planetaries have moved. I don't have the tools to do it, so off it goes tomorrow to a rebuilder who knows about them. I love spending money on something that is brand-new and very few left to buy...
A-Body's RULE!
[Re: Rhinodart]
#1557961
01/03/14 10:14 AM
01/03/14 10:14 AM
Posts: 20,646 in a cattle trailer down by th...
Guitar Jones
Why don't you take it back to the dealer you bought it from? It would only take a trans tech about 15 minutes to align it all back up.
[Re: Guitar Jones]
#1557962
01/03/14 12:08 PM
01/03/14 12:08 PM
Rhinodart
Rhinotruck
Rhinotruck
Like in other posts about dealers I only use one and they are 2 hours away. Chrysler is out of the overdrive units due to cracking of the cases so I feel pretty lucky just to have a new one as it is!
A-Body's RULE!
