speedometer reset knob #1557378
01/01/14 04:55 PM
01/01/14 04:55 PM
KY
70cudaMD Offline OP
70cudaMD  Offline OP
KY
How do I remove the silver reset knob from the shaft on a speedometer from a 70 rallye dash? Need to get it through the cover and don't want to break it. Thanks and Happy New Year.
Re: speedometer reset knob [Re: 70cudaMD] #1557379
01/01/14 04:58 PM
01/01/14 04:58 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
there is a set screw in the center, it should pull off if the screw is removed
Re: speedometer reset knob [Re: 70cudaMD] #1557380
01/01/14 04:59 PM
01/01/14 04:59 PM
Kirkland, Washington
Pacnorthcuda Offline
Use a very small screwdriver while holding the knob still. Look closely, you'll see a very small screw in the center of the knob. Don't lose it!
Re: speedometer reset knob [Re: Pacnorthcuda] #1557381
01/02/14 12:32 AM
01/02/14 12:32 AM
KY
70cudaMD Offline OP
70cudaMD  Offline OP
KY
Thanks.
