Re: New Gen Hemi ?
[Re: Duner]
#1556781
01/01/14 06:35 PM
01/01/14 06:35 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I hope to start on a Hemi here pretty soon... of course with boost.
I'd like to shoot for 1,000hp and see how close it comes.
Blaine are you thinking blower or turbo
Re: New Gen Hemi ?
[Re: Duner]
#1556783
01/01/14 06:41 PM
01/01/14 06:41 PM
MR_P_BODY
Turbo for sure. I've been more or less gearing all mods towards the eventual Hemi setup. I don't see why it couldn't be done - given what the 360 had given me so far with it's limited cylinder heads I'm running.
Cool... thats sorta the direction I am thinking if I find a 5.7 that'll go into my Rampage
Re: New Gen Hemi ?
[Re: MR_P_BODY]
#1556784
01/01/14 06:49 PM
01/01/14 06:49 PM
Posts: 1,969 Chandler, AZ
Duner
Chandler, AZ
That sounds like a blast. I love your little Rampage!
I'm just keeping my eyes open for a donor engine to start it off. I'm sure a cheap one will fall into my lap when I'm not looking too hard.
Re: New Gen Hemi ?
[Re: Duner]
#1556785
01/01/14 07:04 PM
01/01/14 07:04 PM
MR_P_BODY
Thanks... I will start looking with interest in the spring.. unless someone sets me on to one in the next couple of weeks... after that I'm headed to Texas for a couple of months
Re: New Gen Hemi ?
[Re: hemidup]
#1556786
01/01/14 08:31 PM
01/01/14 08:31 PM
Posts: 12,393 Taxes & Virus's R-US, NY
Dragula
Here's a E85 G3 Hemi that made peak 667hp @ 6500rpm and 570ft,lbs/tq @ 5500 rpm at the last dyno session. 436" with a tame 540ish/550ish .600" lift @ .050" with a 116+4 LSA. Factory Eagle heads with a pocket port job that flowed a tad over 370 cfm @ .600" and 10.0:1 compression. The engine was built for boost.
Now lets say the compression was jacked to 12.5:1 and a real man's cam was installed and could make power past the peak 6500 rpm to say 7500?
So lets dicuss this one more you posted....What is the current CR? You say its designed for boost, so is it 8.8:1 or so, and how much boost is it to be run on? The 660hp I am assuming was made without boost?
Me, I would slap a Modman on it and a Whipple 2.2L and a carb and let it rip...
Re: New Gen Hemi ?
[Re: 1967dartgt]
#1556791
01/02/14 03:28 AM
01/02/14 03:28 AM
Posts: 4,302 Nebraska
72Swinger
Nebraska
Here is a thread from LX forums that shows what is basically the latest most cutting edge Gen III stuff http://www.lxforums.com/board/showthread.php/345874-Whats-going-on-at-PWR-11-13-13I think Barton has some pretty sweet stuff coming out of his shop as well $$$$$$$. I only care about power per dollar and reliability these days from my Mopar really, and the Gen III fits the bill for me on paper once you get past the efi buy in and the supporting stuff like headers,oil pan etc. How exotic it is doesnt really blow my skirt up.
Mopar to the bone!!!
Re: New Gen Hemi ?
[Re: MattW]
#1556796
01/09/14 03:23 AM
01/09/14 03:23 AM
Posts: 9,719 Home
SRT6776
I hate internal combustion engines!
Home
Now if we can get Fiat to make the hellcat block in iron and siamese that would be the last ingredient in a winning combination. Matt
AFAIK the Hellcat block is going to be iron, even though it probably should be aluminum to get some weight off those cars.
Re: New Gen Hemi ?
[Re: SRT6776]
#1556797
01/09/14 01:50 PM
01/09/14 01:50 PM
Posts: 2,776 Ontario Canada
MattW
Ontario Canada
I think it was allpar that stated the aluminum block. As far for weight I would rather they trim it somewhere else. It would be real cool to see compact graphite iron. This would save even more weight. The 6.4 is a very strong block. Norms garage just released a 6.4 challenger that make over a 1000 HP with a blower. If the numbers are anywhere near that the block is good for most of the stuff that guys will through at it. AFAIK a blower motor is not easy on a block.
