Page 1 of 7 1 2 3 4 5 6 7
Is 380 mm rotors large enough for you? #1556585
12/31/13 04:00 AM
12/31/13 04:00 AM
Utah and Alaska
astjp2 Offline OP
astjp2  Offline OP
Utah and Alaska
I found 380 x 34 mm (15" x 1.375") rotors that will fit on my drum brake spindles with Brembo calipers for $600 plus about 120 for .400" thick chromoly steel adapters. Would this be too much for a street car? What size wheels would I have to run? I am really considering this because its off the shelf parts with an adapter that I can get cut out on the water jet. Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Is 380 mm rotors large enough for you? [Re: astjp2] #1556586
12/31/13 10:11 AM
12/31/13 10:11 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
19" wheel minimum. 2010+ Mustang wheels have a few options in that diameter.
Mopar to the bone!!!
Re: Is 380 mm rotors large enough for you? [Re: 72Swinger] #1556587
12/31/13 12:11 PM
12/31/13 12:11 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
If the rotors are cheap enough, you can always cut them down so they don't need as big of a wheel.
**Photobucket sucks**
Re: Is 380 mm rotors large enough for you? [Re: 70Cuda383] #1556588
12/31/13 01:19 PM
12/31/13 01:19 PM
The Netherlands
BigBlockMopar Offline
The Netherlands
At what point becomes a discrotor just a flywheel with stored energy for the car in question?
Big enough?
Not quite sure about the cheap part though...
Re: Is 380 mm rotors large enough for you? [Re: astjp2] #1556589
12/31/13 02:07 PM
12/31/13 02:07 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
As long as you don't might the weight of a rotor that size may be, or running the 19" or 20" wheels...sounds like a decent deal for rotors and calipers (depending on just what Brembos they are?)
I stick with 360mm rotors on mine along with the 8 piston Brembos as I don't want to run larger than an 18" wheel on my car..
Re: Is 380 mm rotors large enough for you? [Re: BigBlockMopar] #1556590
12/31/13 02:08 PM
12/31/13 02:08 PM
NW Chicago suburban area
Mopar Mitch Offline
Mopar Mitch  Offline
Now THAT's "Handling on Rails"
Best wishes for the New Year!
Re: Is 380 mm rotors large enough for you? [Re: astjp2] #1556591
12/31/13 02:11 PM
12/31/13 02:11 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
So what is the goal? Bragging rights, bling, mechanical mounting challenges, etc? Too big of brakes may make you warm and fuzzy and peace of mind, while you study the bumper of the guy that just passed you. Unsprung weight, and the flywheel effect mentioned which is valid at BOTH ends of the straightaway, and normally cost, which the Op has overcome. are all concerns, bottomline, the wrong solution at a good price, is still the wrong solution. Now if the OP is overheating his ducted brakes repeatedly, step up, but might want to figure out how to lighten the car, which has many benefits, reduced braking requirements being one.
Re: Is 380 mm rotors large enough for you? [Re: jcc] #1556592
12/31/13 03:09 PM
12/31/13 03:09 PM
Woodinville, WA
Viol8r Offline
Viol8r  Offline
Woodinville, WA
I much prefer moderate size rotors that are available at any moment and not an arm and a leg. We run cooling to our brakes, to me this is a lot cheaper then dealing with 14"+ rotors. For us it comes down to the Caliper, pads and cooling.
1968 Pro-Touring Dodge Charger
*2011 Optima Ultimate Street Car Challenge Invitee
http://www.popularhotrodding.com/features/1203phr_1968_dodge_charger/index.html
Re: Is 380 mm rotors large enough for you? [Re: Viol8r] #1556593
12/31/13 03:23 PM
12/31/13 03:23 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
FWIW...my rotors were about $165 each for genuine Mercedes ones.
If you can design a brake package around some OE components at least, you can do it for a pretty decent price.
Could always go with some carbon rotors to save some weight I suppose.
Re: Is 380 mm rotors large enough for you? [Re: jcc] #1556594
12/31/13 03:29 PM
12/31/13 03:29 PM
Utah and Alaska
astjp2 Offline OP
astjp2  Offline OP
Utah and Alaska
I actually like doing the research and figuring out how to make things work. I like thinking outside the box and finding applications that I can make fit. It takes a lot of money to but caliper brackets and rotors just to see if I can make them fit, so I have been just doing the math and calculations lately.
I have laid out the rotor brackets in cad and had them cut on a water jet for the ones that are presently on my car now from 4140, I am still wondering if I should make a set from aluminum. They are .375 thick if aluminum, .400 in 4140 precision ground plate. I could do the same thing with the 380 mm rotors, the hat height on the 380's would require me to use 2 brackets that are bolted together to offset the caliper bracket to get the right offset.
The 305mm rotors that I have now have brackets that are 1 piece and require 17" wheels to clear the calipers. The 380's would require 19" wheels. I like the idea of larger wheels for better handling but I hate the rubber band look. I am just pondering about this as a project. Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Is 380 mm rotors large enough for you? [Re: astjp2] #1556595
12/31/13 03:35 PM
12/31/13 03:35 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
A cad and a water jet sure would be nice..I made my brackets the "old fashioned" way
Re: Is 380 mm rotors large enough for you? [Re: OzHemi] #1556596
12/31/13 03:51 PM
12/31/13 03:51 PM
SoCal
MuuMuu101 Offline
I got lucky at Woodward!
MuuMuu101  Offline
SoCal
With super-precision eyeballs and hands accurate enough to the closest tolerance of .050"?
Re: Is 380 mm rotors large enough for you? [Re: MuuMuu101] #1556597
12/31/13 03:54 PM
12/31/13 03:54 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
Re: Is 380 mm rotors large enough for you? [Re: astjp2] #1556598
12/31/13 10:25 PM
12/31/13 10:25 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
My 360 mm rotors tip the scales at 37 pounds. EACH.
Are you sure you want to go larger?
I bought my brakes 9 years ago when big brake kits were not readily available for our cars.
Scrounging around in our inventory gave me a 4 wheel big brake kit cheaper than the 13" front-only brakes offered at the time.
Keep it at 13" or less and make your life easy.
Also, don't forget to check the caliper clearance for the back of the wheel. That was a major issue for me (and Oz).
- Stu Harmon
Re: Is 380 mm rotors large enough for you? [Re: feets] #1556599
12/31/13 10:42 PM
12/31/13 10:42 PM
Fly Over States
P
PHJ426 Offline
PHJ426  Offline
P
Fly Over States
Here is some info on Formula 1 carbon rotors with ERS energy recovery system sounds $$$$$$
http://www.formula1.com/inside_f1/understanding_the_sport/5284.html
First one on Moparts with these brakes wins
Re: Is 380 mm rotors large enough for you? [Re: PHJ426] #1556600
01/02/14 03:50 AM
01/02/14 03:50 AM
Utah and Alaska
astjp2 Offline OP
astjp2  Offline OP
Utah and Alaska
I was just thinking that I could do this because its fairly cheap (under 1200), I can match the fronts and rears from the original vehicle, and there is some cool factor to having rotors that fill the wheel well. The rears are 13" along with a hydroboost and a system that is designed for a 6000# vehicle.
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Is 380 mm rotors large enough for you? [Re: astjp2] #1556601
01/02/14 04:01 AM
01/02/14 04:01 AM
Utah and Alaska
astjp2 Offline OP
astjp2  Offline OP
Utah and Alaska
Ignore the arrows!
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Is 380 mm rotors large enough for you? [Re: astjp2] #1556602
01/02/14 06:13 AM
01/02/14 06:13 AM
The Netherlands
The Netherlands
Nifty little brake pad you're holding there.
Looks a bit glazed over though...
Hey at least I ignored the arrows...
Re: Is 380 mm rotors large enough for you? [Re: astjp2] #1556603
01/02/14 03:45 PM
01/02/14 03:45 PM
Houston, Tx
AlexP Offline
AlexP  Offline
Houston, Tx
Are those calipers on a Cayenne Turbo S?
My Build thread: Let the hemi swap begin!
1968 wanna be pro touring whatchamacallit with some fancy stuff and a new roof skin.
Re: Is 380 mm rotors large enough for you? [Re: AlexP] #1556604
01/02/14 04:21 PM
01/02/14 04:21 PM
Utah and Alaska
astjp2 Offline OP
astjp2  Offline OP
Utah and Alaska
Nope, large SUV, they have the largest brakes of any 1/2 class ton suv out there....
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
