Re: Detonation?
[Re: sam64]
#1556368
12/30/13 11:05 PM
12/30/13 11:05 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
Not detonation.... Debris. Something went through the engine.
Re: Detonation?
[Re: sam64]
#1556369
12/30/13 11:07 PM
12/30/13 11:07 PM
Posts: 43,274 Bend,OR USA
Cab_Burge
Re: Detonation?
[Re: Cab_Burge]
#1556370
12/30/13 11:27 PM
12/30/13 11:27 PM
Posts: 1,285 okla.
sam64
okla.
Pitting can be the early signs of detonation, pull those two rods and pistons out and look real hard at the rings and ringlands for damamge Which intake and carb are you running? Also which brand and spark plug heat range? Can you add a good close up picture of those two plugs? BTW,if the rod bearings fall out of the rods, no crush left, that is a sure sign of detonation also
done chunked the plugs,m1 intake w 1050 dom jetted 90 square,timing was 38 deg.the head looks the same on those 2 cylinders.yes the bottom end will come apart later,using the heads on a 499 lowdeck.
Re: Detonation?
[Re: sam64]
#1556371
12/30/13 11:31 PM
12/30/13 11:31 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Is this a sign of detonation?only 2 pistons have this 6&8. Spark plugs look ok,fat if anything.they are off my sr headed 512 low deck running 110 fuel.
I think that is early signs of detonation... if you look close you can see it gets worse the farther out it goes towards the edge of the piston
Re: Detonation?
[Re: sam64]
#1556374
12/30/13 11:50 PM
12/30/13 11:50 PM
TRENDZ
Milwaukee WI
you will need to look, but i'd bet that the pits are actually dents. the heads and pistons will be mirror image patterns.
Re: Detonation?
[Re: TRENDZ]
#1556375
12/30/13 11:57 PM
12/30/13 11:57 PM
MR_P_BODY
If this was debris it should have marks on the cyl wall also in that area.... JMO
Re: Detonation?
[Re: TRENDZ]
#1556376
12/31/13 12:07 AM
12/31/13 12:07 AM
Posts: 1,285 okla.
sam64
okla.
yes pretty much,the head looks the same as the piston but the cylinders don't look bad.it's odd that it's only those 2 cylinders.at least this one made 8 passes,last one ate the cam in 2 passes.
Re: Detonation?
[Re: sam64]
#1556377
12/31/13 12:12 AM
12/31/13 12:12 AM
MR_P_BODY
I would expect the head to look similar if its detonation but not the cyl wall
Re: Detonation?
[Re: loaderpro]
#1556381
12/31/13 11:28 PM
12/31/13 11:28 PM
Posts: 1,285 okla.
sam64
okla.
The next time you pull that engine down you need to smooth out ALL the sharp edges from around the valve reliefs and the crown , this will increase airflow and help to reduce detonation. Sharp edges on any race piston is a definate no-no. This is a CP 14-1 piston with the edges gone.
I will look into doing that.and thanks to all that replied.happy new racing year to all!!
Re: Detonation?
[Re: JACK1440]
#1556386
01/04/14 04:23 PM
01/04/14 04:23 PM
Posts: 5,166 CT
GTX MATT
CT
Detonation, 38 degrees is too much timing for closed chambered heads and good quench, it would probably be faster with 34 degrees and not detonate.
