If you somehow REALLY screwed this up, and have cranked the engine, don't dispair, several very easy steps:
Pull the NO1 plug, and with a remote button or helper "bumping the starter, get a good view of the timing tab, and bump the starter, while holding your finger in the empty plug hole.
While CAREFULLY bumping the starter, feel for the compression decidedly pushing your finger out of the hole. At this time, watch for the mark, and bump the engine (maybe with a wrench) so the marks are somewhere 0-10*.
Now look at the distributor. Rotate the dist. so the vacuum advance is "in the middle" with range to move it. Whichever tower the rotor is pointing to is where the NO1 wire goes!!!
If you don't want it there, pull the dist and rotate the rotor 180 and stick it back in--you note it only goes two ways
The only reason on MOST engines that the manuals specify a certain tower for no1 is:
so the factory workers can rig the engines out the same
so the plug wires "lay" neatly
and so the mechanics later on "see" what they expect on car after car.
