Re: Slicks vs radials [Re: StealthWedge67] #1556035
12/31/13 05:08 AM
12/31/13 05:08 AM
Salisbury North Carolina
8secDart Offline
8secDart  Offline
I understand and agree with the consitency thing with Bias Ply slicks; but if its a street / strip car: No brainer as far as I'm concerned.... RADIALS. Having the car wander around on the street with Bias ply tires is not something that interests me. And I've done a few passes with Bias Slicks, and radials up front.... That was flat out scary at the top, NO THANKS!
Now, I'll admit I have the luxury of both tracks I get to are always very well prepped, but still I don't think there's anything that would cause me to go to bias ply tires for a street car.
If your car drove like that on the big end you had to low PSI in rear tires.The rear and front tires have no idea which one is on either end.That is just plain and simple BS.
I'm not the only one that has experienced ill handling with a mix of Radials up front and Bias plys out back. Radials and Bias Plys will track differently, which can create problems. No sir, it wasn't just because I had the pressure wrong, and No Sir, it is not BS. What I will admit to, is that I looked back at the O.P., and realize that I was wrong about the street driving. I see now that it is a 100% strip car. In that case, I would go Bias-Plys. But, I would still NOT mix them.
I have run every tire combo under the sun. If it is wagging in the lights it is low of rear PSI. The Tire tracking different on the track is BS.I have run 3,800lbs cars at over 160mph so I can say it is BS. Having them noses in the air may have something to do with it to. Radials drive better only because most times you run more PSI in them.
Re: Slicks vs radials [Re: 8secDart] #1556036
12/31/13 02:56 PM
12/31/13 02:56 PM
Saskatchewan (SK)
79410aspenrt Offline OP
Saskatchewan (SK)
i have noticed that with low air pressure that my car would sway at the top end. put 2 psi in and swaying solved. didn't matter which brand it was, to low of air pressure, car swayed.
since i have a strip only car, Mickey Thompson drag slicks is my choice. only makes sense, drag car = drag slicks.
Re: Slicks vs radials [Re: 79410aspenrt] #1556037
12/31/13 03:53 PM
12/31/13 03:53 PM
Owego, NY
JBurch Offline
JBurch  Offline
Owego, NY
I'm no expert, so here's my : I've gotten my best 60ft time running M/T drag radials; 1.445 on a reasonably well prepped track, a couple of weeks later at a different track, not as well prepped my 60ft fell off to 1.8**. When Drag Radials start to spin (at least M/T's)they don't recover and it feels like your on ice; slicks may not bite as hard, though they will be more consistent.
How hard do you want to race, and how much do you want to win?
Re: Slicks vs radials [Re: JBurch] #1556038
12/31/13 04:11 PM
12/31/13 04:11 PM
Riverside, Ca
G_bob Offline
G_bob  Offline
Riverside, Ca
Just for the record, my experience as related above is with radial slicks. I get the impression that most of the time when using the term, "drag radials", folks are referring to ET Street radials, or another version of a street/strip radial. A true radial slick is a totally different beast and is still picky about track prep in comparison to a bias ply slick, at least in my limited experience. Quick time pros were more consistent for me than the true radial slick.
Re: Slicks vs radials [Re: 79410aspenrt] #1556039
12/31/13 04:17 PM
12/31/13 04:17 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I have ran both ET Street Radials and slicks, my car is faster on the radial. If the track is not prepped well the radials will spin. For bracket racing I have a set of bias slicks.
