Page 6 of 8 1 2 3 4 5 6 7 8
Re: NEED PICS OV VERTICALLY MOUNTED SHOCKS................. [Re: 1967dartgt] #1555821
03/03/14 09:13 PM
03/03/14 09:13 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
The front shock to eliminate the bushin.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: NEED PICS OV VERTICALLY MOUNTED SHOCKS................. [Re: 1967dartgt] #1555822
03/03/14 09:14 PM
03/03/14 09:14 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Re: NEED PICS OV VERTICALLY MOUNTED SHOCKS................. [Re: 1967dartgt] #1555823
03/04/14 12:53 AM
03/04/14 12:53 AM
State of confusion
Thumperdart Offline OP
State of confusion
As crazy as it sounds, Travis at Calvert Racing doesn`t get the "in ft. of axle" deal and said that`s news to him.
Re: NEED PICS OV VERTICALLY MOUNTED SHOCKS................. [Re: 1967dartgt] #1555824
03/04/14 01:06 AM
03/04/14 01:06 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
I am sure you saw gups pic of his rear suspension, so I am by no means the inventor of this idea. His car has been that way as long as I have know it. I just copy other people good ideas.lol
Re: NEED PICS OV VERTICALLY MOUNTED SHOCKS................. [Re: 1967dartgt] #1555825
03/04/14 02:05 AM
03/04/14 02:05 AM
State of confusion
State of confusion
I hear ya man and do the same thing sometimes but for now I`m leaving the shocks and ft. mount alone and just doin shackles and slicks and lettin it ride. Just for giggles you should call Calvert and talk to Travis and see his perspective since I can`t remember everything he said................
Re: NEED PICS OV VERTICALLY MOUNTED SHOCKS................. [Re: Thumperdart] #1555826
03/04/14 08:16 AM
03/04/14 08:16 AM
Melbourne , Australia
LA360 Offline
LA360  Offline
There have been some posts on the Bullet from some of the heavy hitters in the small tire leaf spring classes. These guys had run the shock behind, or in front of the housing. Their shock data was smoother with the shock mounted in the front (rear mounted the graph would spike) and the car was quicket and more consistant.
Alan Jones
Re: NEED PICS OV VERTICALLY MOUNTED SHOCKS................. [Re: LA360] #1555827
03/04/14 01:47 PM
03/04/14 01:47 PM
State of confusion
State of confusion
I`m no expert and just repeating what Travis said and one thing I remember was w/the shock in back you`re controlling more of the rear of the car and w/it in ft. it`s controlling some of the ft. of the car..........
Re: NEED PICS OV VERTICALLY MOUNTED SHOCKS................. [Re: Thumperdart] #1555828
03/04/14 04:37 PM
03/04/14 04:37 PM
MR_P_BODY Offline
MR_P_BODY  Offline
The car is being lifted at the same point which is
the front of the spring at the bolt hole... with a shock
on the rear it will see a farther travel than if its
in front.... its a matter of what the shock likes
that makes the difference... its pushing oil through
a set of holes... now does it like the pressure of
the oil to be higher(with the shock in the rear) or
with the pressure to be lower(with the shock in front)..
the higher and lower pressure is from the distance
that the piston travels in the shock(its mounted on
the shaft)... not all shocks are equal.. when I took
the Dave chassis seminar he spoke alot on shocks and
how some react to different inputs
Re: NEED PICS OV VERTICALLY MOUNTED SHOCKS................. [Re: 1967dartgt] #1555829
03/05/14 03:59 PM
03/05/14 03:59 PM
Texas
dannysbee Offline
dannysbee  Offline
Texas
The caltrac controls rotation, you want to be on front because that is the part of the spring that dictates traction. It reacts faster when you are on the front.
I thought the post was about vertical mounted shocks. My thoughts are more along the line of controlling the spring in a leaf spring application (no snubber no bars) but I can still see some possible benifit with a caltrac car, especially a radial car where you are trying to dampin the initial hit on the tire. How much negative pinion angle does caltrac recommend?
Getting old just means you were smarter than some and luckier than others.
Re: NEED PICS OV VERTICALLY MOUNTED SHOCKS................. [Re: dannysbee] #1555830
03/05/14 04:14 PM
03/05/14 04:14 PM
State of confusion
State of confusion
Travis likes between 2-4 degrees nose down.................Now I`m a 7 w/all of the changes so................
Re: NEED PICS OV VERTICALLY MOUNTED SHOCKS................. [Re: Thumperdart] #1555831
03/05/14 05:13 PM
03/05/14 05:13 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
I will fit mine in front of the axle because it's mounted an inch further back, so it will straighten the shocks up both ways. It's got to be at least 6" forward with the spring clamps reversed.
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: NEED PICS OV VERTICALLY MOUNTED SHOCKS................. [Re: deaks] #1555832
03/10/14 05:16 PM
03/10/14 05:16 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
I have fitted my shocks the same as 67 dart GT and at rest there's only 3/4" compression, that is without me.
I have only tacked the upper plates at the moment, so i can break the welds but the trunk floor curves down near the top of the shocks so either i need to cut the floor and remake that section, hammer it upwards,change my 1-1/2 lowering blocks for 2" ones, or cut the bottom bolt off the plate and fab something onto it to make it hang lower.
Any suggestions ?
best 60ft 1.36
Re: NEED PICS OV VERTICALLY MOUNTED SHOCKS................. [Re: deaks] #1555833
03/10/14 05:25 PM
03/10/14 05:25 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Get shorter shocks.
Re: NEED PICS OV VERTICALLY MOUNTED SHOCKS................. [Re: 1967dartgt] #1555834
03/10/14 05:39 PM
03/10/14 05:39 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
They are afco doubles, i'm not buying another set.
How much travel have you got at rest ?
Mick
best 60ft 1.36
Re: NEED PICS OV VERTICALLY MOUNTED SHOCKS................. [Re: deaks] #1555835
03/10/14 06:21 PM
03/10/14 06:21 PM
State of confusion
State of confusion
Mick
I have the 2" recommended compression at rest myself......................
Re: NEED PICS OV VERTICALLY MOUNTED SHOCKS................. [Re: deaks] #1555836
03/10/14 07:02 PM
03/10/14 07:02 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
I have two inches also.
Re: NEED PICS OV VERTICALLY MOUNTED SHOCKS................. [Re: 1967dartgt] #1555837
03/10/14 07:30 PM
03/10/14 07:30 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
Pushing the tube up into the chassis doesn't increase the height much, maybe my afcos were a little short in the first place.
I'll probably lower the bottom mount an inch.
Mick
best 60ft 1.36
Re: NEED PICS OV VERTICALLY MOUNTED SHOCKS................. [Re: deaks] #1555838
03/10/14 08:24 PM
03/10/14 08:24 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
What are you using for lower mount?
Re: NEED PICS OV VERTICALLY MOUNTED SHOCKS................. [Re: 1967dartgt] #1555839
03/10/14 08:40 PM
03/10/14 08:40 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
The stock mount for the SS springs.
best 60ft 1.36
Re: NEED PICS OV VERTICALLY MOUNTED SHOCKS................. [Re: deaks] #1555840
03/10/14 08:59 PM
03/10/14 08:59 PM
bronx n.y
O
one bad fish Offline
O
bronx n.y
mine r straight up
