Page 2 of 4 1 2 3 4
Re: Pictures of Member's Cars Built for Handling [Re: amxautox] #1555480
01/02/14 12:13 AM
01/02/14 12:13 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
I bought the Charger in 2000 with the plans to make it several notches above what I had with my previous "muscle" car.... a 76 Camaro.
The Camaro was required to pass smog testing, so I was limited to a mild cammed small block. The Charger had no such restrictions.
The Camaro was set up with budget based heavy duty factory suspension components. Trans Am sway bars, Station wagon coil springs cut down, urethane bushings and all that. The Charger was bought at a point where I had more money to spend.
The Camaro was lower than my Charger is. The Camaro weighed 3680 with a 700 R4 OD trans and a few lbs more when I switched to a Saginaw 4 speed. It handled great and rarely ever caught me sleeping. The Charger weighs a little more, sits a bit taller but has wider tires. I hesitate to push it as hard on the street as I did with the Camaro. It may be because I have a bunch of money tied up into a car that isn't so easy to replace as a Camaro!
Re: Pictures of Member's Cars Built for Handling [Re: Kern Dog] #1555481
01/02/14 10:27 AM
01/02/14 10:27 AM
Sacramento, Ca
Darius Offline
Darius  Offline
Sacramento, Ca
I am not quite finished with this build yet but it will be at Spring Fling this year. Alterktion and 4 link. i did not do this with intention of racing but I did want a good handling suspension and I think this set up will fill that bill.
Driving modern convenience in classic beauty
Re: Pictures of Member's Cars Built for Handling [Re: Darius] #1555482
01/02/14 10:28 AM
01/02/14 10:28 AM
Sacramento, Ca
Darius Offline
Darius  Offline
Sacramento, Ca
The back end
Re: Pictures of Member's Cars Built for Handling [Re: Darius] #1555483
01/02/14 10:29 AM
01/02/14 10:29 AM
Sacramento, Ca
Darius Offline
Darius  Offline
Sacramento, Ca
Another rear end view
Re: Pictures of Member's Cars Built for Handling [Re: Darius] #1555484
01/02/14 03:11 PM
01/02/14 03:11 PM
hawaii
P
pauly v.100 Offline
pauly v.100  Offline
P
hawaii
Track wanted.
Re: Pictures of Member's Cars Built for Handling [Re: MuuMuu101] #1555485
01/02/14 03:28 PM
01/02/14 03:28 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Does it have to be a Mopar?
They are a tried and true road racing/touring car from Oz, so makes it a little easier knowing what to start out with.
Re: Pictures of Member's Cars Built for Handling [Re: pauly v.100] #1555486
01/02/14 04:49 PM
01/02/14 04:49 PM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
Re: Pictures of Member's Cars Built for Handling [Re: Darius] #1555487
01/02/14 06:20 PM
01/02/14 06:20 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Curious, what are the specs on the 2 lower control arms on that rear end set-up, tube dia, thickness, joint thread size, joint bolt size if different, steel or CM, if you don't mind.
Looks too nice to drive.
Re: Pictures of Member's Cars Built for Handling [Re: Mattax] #1555488
01/02/14 08:20 PM
01/02/14 08:20 PM
hawaii
P
pauly v.100 Offline
pauly v.100  Offline
P
hawaii
Track wanted.
http://www.bigislandscca.org/index.html
http://www.sccahawaii.org/
Oahu SCCA uses the stadium parking lot- no thanks. I'll be relocating to the west coast in the not-to-distant future. In the meantime I'll keep making mods to the car, there's more I want to do to it.
Re: Pictures of Member's Cars Built for Handling [Re: pauly v.100] #1555489
01/02/14 08:25 PM
01/02/14 08:25 PM
On The Boat, On The Lake, Wa. ...
amxautox Offline
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Offline
What's the matter with the stadium parking lot? Got a picture? Autocross uses parking lots a lot.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: Pictures of Member's Cars Built for Handling [Re: jcc] #1555490
01/02/14 10:48 PM
01/02/14 10:48 PM
Sacramento, Ca
Darius Offline
Darius  Offline
Sacramento, Ca
I bought this set up from RMS and I think he just re-sells Air Ride Technologies stuff. I have no specs like you are asking for but you might get them from www.ridetech.com
I did not have this awesome of a project in my minds eye when I started, it sort of evolved but I absolutely intend to drive this car. I have been staring at it for 5+ years and I am SOOOOOOO over just looking at it.
It will be fun to talk to folks about it.
Re: Pictures of Member's Cars Built for Handling [Re: Darius] #1555491
01/02/14 11:00 PM
01/02/14 11:00 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
Triangulated 4 link is what my car used from the factory...
Not a bad setup for a factory setup, but if I was going from scratch think I would go with a 3 link and watts link.
(You could get your roll center and what not dialed right in that way, along with locating the rear better and not have any binding issues either.)
Re: Pictures of Member's Cars Built for Handling [Re: pauly v.100] #1555492
01/03/14 06:01 AM
01/03/14 06:01 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Track wanted.
Spring Fling Speed Festival is April 3, 2014 !!
Would love to have you share in the fun.
Re: Pictures of Member's Cars Built for Handling [Re: amxautox] #1555493
01/03/14 03:31 PM
01/03/14 03:31 PM
hawaii
P
pauly v.100 Offline
pauly v.100  Offline
P
hawaii
The asphalt surface is awful, tire shredder awful.
Re: Pictures of Member's Cars Built for Handling [Re: autoxcuda] #1555494
01/03/14 03:35 PM
01/03/14 03:35 PM
hawaii
P
pauly v.100 Offline
pauly v.100  Offline
P
hawaii
Track wanted.
Would love to, just not this year. I'm looking into relocating to the Portland/Vancouver area, but only after my wife finishes college. -pauly
Re: Pictures of Member's Cars Built for Handling [Re: pauly v.100] #1555495
01/03/14 03:37 PM
01/03/14 03:37 PM
amxautox Offline
amxautox  Offline
Ok, got it. The parking lot we used was in decent shape.
Tom
author unknown
Re: Pictures of Member's Cars Built for Handling [Re: pauly v.100] #1555496
01/03/14 04:49 PM
01/03/14 04:49 PM
Battle Ground, Washington
Rapom65 Offline
Rapom65  Offline
Hey Pauly, if you do relocate to the NW I'd like to be the first to welcome you to the area. Would love to look over your ride someday as I've kept an eye on your posts for years. Who knows, I might even have the pile of parts spread all over my shop bolted back together by the time you make the move!
Re: Pictures of Member's Cars Built for Handling [Re: Rapom65] #1555497
01/04/14 03:22 PM
01/04/14 03:22 PM
hawaii
P
pauly v.100 Offline
pauly v.100  Offline
P
hawaii
Thank you very much. I'm from the Seattle area originally so it won't really be a shocker for me to move. I likely wouldn't consider it except A) My wife prefers cooler weather, and B) its getting very crowded here with no prospect for improvement.
Don't even get me started on the cost of living or the terrible condition of the roads here. -pauly
Re: Pictures of Member's Cars Built for Handling [Re: pauly v.100] #1555498
01/08/14 11:23 PM
01/08/14 11:23 PM
Answering the call of the wild
ThermoQuad Offline
ThermoQuad  Offline
Darius and Pauly have very cool cars.
I would be more than happy to run them for some evaluation laps...
I built this Charger for a friend of mine.
Those are 125 mph certified mudflaps
Eats SRT8 Challengers on the road course.
Re: Pictures of Member's Cars Built for Handling [Re: ThermoQuad] #1555499
01/09/14 03:35 AM
01/09/14 03:35 AM
hawaii
P
pauly v.100 Offline
pauly v.100  Offline
P
hawaii
Beautiful, nice work!
Page 2 of 4 1 2 3 4
