Re: Hemi's & shock towers in "A" & "B" bodies??
[Re: B G Racing]
#1555233
12/29/13 06:13 PM
12/29/13 06:13 PM
Posts: 1,938 Sonora CA
Mopar_Rich
Sonora CA
The simple solution is to weld the shock hole shut and re-drill it aprox, 1" outward.Just weld a steel plate or large steel washer top and bottom to reinforce the new hole.
I agree. Done this before and it's super easy.
[Re: Mopar_Rich]
#1555234
12/29/13 06:26 PM
12/29/13 06:26 PM
Posts: 12,588 Great Neck,LI,new york
hemi-itis
So if it's that way,just have to hit the grinder wheel with the rubber & washer? The posted pic is without a gasket.When I glued the gasket on it wouldn't fit properly.I might still have to drop the shock stud to remove the cover,that's why I was thinking of eliminating the stud from the engine bay
[Re: Mopar_Rich]
#1555237
12/30/13 01:24 PM
12/30/13 01:24 PM
Posts: 9,910 Eighty Four, PA
B G Racing
Eighty Four, PA
With the angle change it doesn't interfere with the vc removal.
