72 -74 B body rear axle Question 81/4 vs 8 3/4 vs 9 1/4 #155513
11/23/08 08:45 PM
11/23/08 08:45 PM
Gateway to the West.
hemi_harvester Offline OP
OK is there any reasoning to which cars got what?
I know the lower performance cars usually received an 8 1/4
but I have seen 73 -74 400 / 440 cars with 8 3/4 and 9 1/4
Any logic to what got what or just what the plant had on hand?
There comes a time in life, when you walk away from all the drama & people who create it. You surround yourself with people who make you laugh, forget the bad, and focus on the good.
Re: 72 -74 B body rear axle Question 81/4 vs 8 3/4 vs 9 1/4 [Re: hemi_harvester] #155514
11/23/08 10:15 PM
11/23/08 10:15 PM
md
mopars4ever Offline
mopars4ever  Offline
md
340 cars had 8 3/4
Re: 72 -74 B body rear axle Question 81/4 vs 8 3/4 vs 9 1/4 [Re: mopars4ever] #155515
11/24/08 08:54 AM
11/24/08 08:54 AM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
HP 4-bbl cars got the 8.75 and all 2-bbl cars got the 8.25
I myself have never seen a 9.25 in a 71-4B from the factory.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: 72 -74 B body rear axle Question 81/4 vs 8 3/4 vs 9 1/4 [Re: moparmarks] #155516
11/24/08 10:50 AM
11/24/08 10:50 AM
I have seen 2 both 74 GTXs
Re: 72 -74 B body rear axle Question 81/4 vs 8 3/4 vs 9 1/4 [Re: hemi_harvester] #155517
11/24/08 11:56 AM
11/24/08 11:56 AM
Ontario
5537SG Offline
super gas
5537SG  Offline
super gas
Ontario
Im under the impression that the 8.75 was last used in 73. Although I make no claim that Im knowledgeable on such topics.
My 73 340 Charger has/had the 8.75
Re: 72 -74 B body rear axle Question 81/4 vs 8 3/4 vs 9 1/4 [Re: moparmarks] #155518
11/24/08 12:04 PM
11/24/08 12:04 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
they are at least listed on the axle guide... but is true, I never have seen them either
Re: 72 -74 B body rear axle Question 81/4 vs 8 3/4 vs 9 1/4 [Re: NachoRT74] #155519
11/24/08 12:16 PM
11/24/08 12:16 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
The only early '70s B-body 9 1/4" rear I noticed was in a '74 400 HP automatic Charger.
Re: 72 -74 B body rear axle Question 81/4 vs 8 3/4 vs 9 1/4 [Re: DoctorDiff] #155520
11/24/08 01:17 PM
11/24/08 01:17 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
I have one NOS down here, with suregrip conekind, but is just teh housing with carrier. no axles, cover, brake lines or anything
Re: 72 -74 B body rear axle Question 81/4 vs 8 3/4 vs 9 1/4 [Re: hemi_harvester] #155521
11/24/08 01:24 PM
11/24/08 01:24 PM
IMGTX Offline
IMGTX  Offline
The HP and some other big cars were supposed to get the 8-3/4 through the early part of 74. The later part of 74 they dropped the 8-3/4 for the 9-1/4.
The light duty B bodies were supposed to get the 8-1/4.
Re: 72 -74 B body rear axle Question 81/4 vs 8 3/4 vs 9 [Re: IMGTX] #155522
11/24/08 03:05 PM
11/24/08 03:05 PM
St Louis, Missouri
Runnin74 Offline
Runnin74  Offline
St Louis, Missouri
My 74 Road Runner was built in December '73 and has an 8 3/4.
Re: 72 -74 B body rear axle Question 81/4 vs 8 3/4 vs 9 1/4 [Re: NachoRT74] #155523
11/24/08 04:19 PM
11/24/08 04:19 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
How did you come up with all that NOS drivetrain stuff?
I have an NOS C-body 9.25" (Dana 53) housing.
Re: 72 -74 B body rear axle Question 81/4 vs 8 3/4 vs 9 1/4 [Re: IMGTX] #155524
11/24/08 09:10 PM
11/24/08 09:10 PM
near Harrisburg, Pa
440trk Offline
440trk  Offline
near Harrisburg, Pa
You sir, are CORRECT!
The 8 3/4 went away in 74 (at some point) and the 9 1/4" replaced it. I have the 73/4 parts manual around here somewhere...If I can find the changeover date, I'll post it back.
This is also true of Dodge trucks.
I am, however, curious as to what rear a late build 74 360 4spd Cuda/Challenger would have had.... I've never seen a 9 1/4" E-body rear.
Re: 72 -74 B body rear axle Question 81/4 vs 8 3/4 vs 9 1/4 [Re: DoctorDiff] #155525
11/24/08 10:19 PM
11/24/08 10:19 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Chrysler had assembly plants and dealers here , and some of them still have Old Stock.
actually they are still here, after a break for 13 years Chrysler left Venezuela ( 79-92 )
I got this housing with SG carrier thinking on upgrade my 8 3/4 because perches width is the same, just drum to drum width is a little bit shorter, about 1/2", but never found the axles or cover. Berings needs to be replaced since got some water on storaging and they are rusted.
as far I rememeber, gear ratio is 2.91 or so
Re: 72 -74 B body rear axle Question 81/4 vs 8 3/4 vs 9 1/4 [Re: IMGTX] #155526
11/24/08 11:09 PM
11/24/08 11:09 PM
Oklahoma City
Jwilli500 Offline
Jwilli500  Offline
Oklahoma City
OK just curious, Would a 1975+ B-body 9.25 be bolt in for a 1974 B-body? Iso-mounts included? Sort of a retrofit as it were.
Re: 72 -74 B body rear axle Question 81/4 vs 8 3/4 vs 9 1/4 [Re: NachoRT74] #155527
11/24/08 11:17 PM
11/24/08 11:17 PM
moparmarks Offline
moparmarks  Offline
I've heard of some 74 B's with a 9.25 but just have never seen one myself. Had a couple 74 HP Chargers and both had 8.75 but may have been early cars. Have had a few 74 trucks all with 8.75 rears.
Maybe they just used the 8.75 for the E's through out 74.
All 71/4B's 2-bbl cars both BB and SB and 6 cyl that I've owned had 8.25
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: 72 -74 B body rear axle Question 81/4 vs 8 3/4 vs 9 1/4 [Re: moparmarks] #155528
11/24/08 11:56 PM
11/24/08 11:56 PM
US of A
A38s! Offline
A38s!  Offline
US of A
I've a 73 Sat 400 Wagon with trailer pkge and 9.75 open.
I assume RK, WK, some wags, and tow packs would all be likely prospects.
(I like the edit function)
WANTED: Your 71-78 Late B-body sedan parts! Police or Civilian.
Re: 72 -74 B body rear axle Question 81/4 vs 8 3/4 vs 9 1/4 [Re: moparmarks] #155529
11/25/08 12:28 AM
11/25/08 12:28 AM
NE Ohio
71 FJ6 Charger Offline
NE Ohio
I used to have 2 survivor cars,a 73 Charger SE 400 2bbl auto with 3.23 8 3/4,and a 73 Rallye 400 HP auto with 3.55 8 3/4.
'71 383HP FJ6 Charger SE
Re: 72 -74 B body rear axle Question 81/4 vs 8 3/4 vs 9 1/4 [Re: 71 FJ6 Charger] #155530
11/25/08 01:22 AM
11/25/08 01:22 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I've got a 9.25 w/3.55's in mine, no idea if it's stock or not though. Anybody know why they switched from the dana to the 9.25? Cheaper I assume?
Re: 72 -74 B body rear axle Question 81/4 vs 8 3/4 vs 9 1/4 [Re: DaytonaTurbo] #155531
11/25/08 01:50 AM
11/25/08 01:50 AM
Sacramento, CA
K
Kirk_Ingram Offline
super street
Kirk_Ingram  Offline
super street
K
Sacramento, CA
I have a 9.25" in a 71 RR, came with the car when I got. I know its not factory...I THINK it came from a 75 Monaco dunno for certain. The fit is perfect though.
I pulled a rear sway bar out of a 75 B-car many years back, with ISO leaf plates, 9.25 rear also.
I didn't know the 9.25" was referred to as a Dana 53, however, I DID know the carrier's were Spicer units (hard miss the DIAMOND stamp). Thanks Dr. Diff for that little tid-bit.
Death or Glory...it's just another story.
Re: 72 -74 B body rear axle Question 81/4 vs 8 3/4 vs 9 1/4 [Re: DaytonaTurbo] #155532
11/25/08 01:54 AM
11/25/08 01:54 AM
near Harrisburg, Pa
440trk Offline
440trk  Offline
near Harrisburg, Pa
There's a chance yours is a legit 74 B-body 9 1/4. As far as I know, they were available with either 3.21 or 3.55 Sure-grip rears. I don't think the 74's B-body 9-1/4" were produced with an open diff. :shruggy? They are not overly common...in ALL the 71-4 B-bodies I've seen in the last 21 years of messing with specifically these cars....I've seen 2 9-1/4" rear cars.
The Dana 60 was no longer used in passenger cars after 1972.
I'm guessing the 9-1/4" rear is cheaper to produce than the 8-3/4", hence it's eventual replacement.
