Not your Avrage fender tag ? GURUS ck this out. #155503
11/23/08 08:40 PM
11/23/08 08:40 PM
Gateway to the West.
hemi_harvester Offline OP
THis is from a 74 Charger I looked at today. First anyone know what the top numbers are?
Second this car is a stripper but had 2 tags second tag had the numbers 1 thru nine in 2 rows at the bottom with holes punched thru some numbers.
take a look..
There comes a time in life, when you walk away from all the drama & people who create it. You surround yourself with people who make you laugh, forget the bad, and focus on the good.
Re: Not your Avrage fender tag ? GURUS ck this out. [Re: hemi_harvester] #155504
11/23/08 08:43 PM
11/23/08 08:43 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Lynch road option tags are all like that.
Gate / line sequnce numbers, etc.
The second tag is just an inspectors tag.
Re: Not your Avrage fender tag ? GURUS ck this out. [Re: Alaskan_TA] #155505
11/23/08 08:53 PM
11/23/08 08:53 PM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
The top row contains the gate/base and sequence numbers like Barry said. The next numbers are the engine, tranny and axle codes.
518= Engine: B,E body 318-2bbl with AT and A/C
182= rear axle code
843= Tranny: A,B,E body 904 behind a 318/early code
Pretty standard LR tag.
