Safety recall 03-08 Ram #1554769
12/28/13 04:38 PM
12/28/13 04:38 PM
Round Lake Beach, Illinoisy
Rhinodart Offline OP
Rhinotruck
Rhinotruck
Just got a recall notice on my 04 Ram 3500. It says that the steering linkage may need to be replaced. The left tie rod ball stud may break. My question is that it does not say two or four wheel drive and mine is a 4x4, anyone know anything about this?
JB Rhinehart, Realist
A-Body's RULE!
Re: Safety recall 03-08 Ram [Re: Rhinodart] #1554770
12/28/13 04:45 PM
12/28/13 04:45 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Just call your local dealer and they will run your VIN to see if it's one of those involved.
Re: Safety recall 03-08 Ram [Re: stumpy] #1554771
12/28/13 04:57 PM
12/28/13 04:57 PM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
It only applies to trucks that have had the steering linkage replaced under warranty with MOPAR replacement parts. If your truck still has its original steering linkage it does not apply. It applies to the 4wd trucks only. 2wd trucks have rack and pinion steering
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: Safety recall 03-08 Ram [Re: 71yelladustr] #1554772
12/28/13 09:36 PM
12/28/13 09:36 PM
Rhinotruck
Rhinotruck
I did not buy the truck new, so I have no idea if anything was replaced. I will call the dealer, but the truck is in another shop to replace the transfer case and overdrive right now.
A-Body's RULE!
Re: Safety recall 03-08 Ram [Re: Rhinodart] #1554773
12/28/13 11:54 PM
12/28/13 11:54 PM
Missouri U.S.A.
Missouri U.S.A.
Here is an easy check to see if yours is one of the recalled units. Look where the steering dampner mounts to the drag link. If it is fastened to it with a bracket with 2 u-bolts, it is a MOPAR replacement piece. The factory steering linkage will have a stud that goes through the drag link that the steering dampner attaches to.
10.02@134
Re: Safety recall 03-08 Ram [Re: 71yelladustr] #1554774
12/29/13 12:33 AM
12/29/13 12:33 AM
Rhinotruck
Rhinotruck
WHAT? Work on and/or look at my own vehicle?
A-Body's RULE!
Re: Safety recall 03-08 Ram [Re: Rhinodart] #1554775
12/29/13 12:30 PM
12/29/13 12:30 PM
Norwich CT USA
moparts Offline
moparts  Offline
Norwich CT USA
I just got the sane tie rod recall,
BUT it lists 2008-2012 trucks and my 4x4 by vin needs to be inspected.
If you got a recall in the mail, the dealer needs to look at it
Tom ,
2011 Ram 3500 C&C Diesel
2009 Challenger R/T
1971 Challenger Conv. 511/4 speed
1970 Challenger R/T 503/727
Re: Safety recall 03-08 Ram [Re: moparts] #1554776
12/29/13 02:37 PM
12/29/13 02:37 PM
Crofton, Ky.
rattler Offline
rattler  Offline
Crofton, Ky.
I got the notice on my 2011 2500. It says to contact the dealer after 1-6-2014.
1957 Dodge truck, Snakeskin Green with a little stroker motor. 1964 Plymouth Savoy wagon ( my new project)
Re: Safety recall 03-08 Ram [Re: rattler] #1554777
12/29/13 03:16 PM
12/29/13 03:16 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
there are three different recalls right now and you need to have them checked by vin.
....and if you've EVER had an alignment done do yourself a favor and take a quick look at your tie rod ends and make sure they are both on the same plain (bottom of joint at same angle on both sides....kind of hard to explain, hope you can vision this). I've seen countless ones that were "cocked" away from each other and if you've seen one of the broken tie rod ends and pull the grease boot off you can see where the problem was.
