First Results from Engine Swap
#1554723
12/28/13 03:46 PM
12/28/13 03:46 PM
dogdays
Well after months of d#$%ing around, the '64Dog made its first journey under new engine power.
Here's what it is: '86 Fifth Avenue 318, home ported 302 heads, thin head gaskets, 1976 T-quad intake, 570 Street Avenger with 52 jets in front on an open adapter, 360 LA roller cam, Crane 833 valvesprings, exhaust manifolds and 2 1/2" dual exhaust. Distributor is an old Direct Connection electronic with the HP curve. Truck runs a 3.23 rear and 32-11.50 x 15 rear tires.
For a clutch I used a Schiefer 11.5" disk and a McLeod 12" B&B high performance pressure plate that bolted to the flywheel in place of the stock 11". Roller pilot bearing from late model Ram.
First of all it took some timing corrections to get it to run. I think my damper ring has slipped, because at 11 degrees initial it would barely run. Twisted the distributor to around 22 degrees initial and it starts every time. So with 22 in the initial I'm running over 40 at full advance, and the engine didn't ping no matter what. I think the damper ring is off, I'll have to check when it gets warmer. Second, with the open adapter it seems to run extremely lean, with stumble on tip-in. Probably the open adapter reduces the signal. Probably should rejet, but..... Mileage was over 20 for long stretches of 70mph driving! I couldn't believe it. Lean carburetion plus tall gears, I guess.
With the Poly I only got 18mpg once, and that was at an even 60 with the two-barrel jets half-filled with gum. With the Avenger and a good tune, I occasionally touched 16 at highway speeds.
So now I try to tune for driveability without sacrificing this great mileage. I also have several Quadrajets to try out. Let me say, 20mpg from the 'Dog is really good news.
On another note, it took 600 miles for the new pressure plate and the new throwout bearing to "wear in" to each other and not make noise when I pushed in the clutch. It's still a work in progress, but maybe I won't have to change parts. I'm hoping the HP clutch/large diameter will be more clutch than any 318 could test.
Happy New Year!
R.
Re: First Results from Engine Swap
[Re: 340SHORTY]
#1554726
12/29/13 02:39 PM
12/29/13 02:39 PM
Posts: 6,048 Back home in PA
BulletBob
Back home in PA
No pics, just hearsay...
DogDays I get the same response sometimes
Now I take my camera almost everywhere I go
[Re: dogdays]
#1554728
12/31/13 01:15 AM
12/31/13 01:15 AM
Posts: 15,487 Florida
scratchnfotraction
Ask me if I care about others' thoughts...meh! My truck is in such bad shape it's embarrassing.
Still I would like to post a pic or two, if only to show off my "new" gold-colored engine.
I've thought about faking it up with a "Golden Lion" emblem from a '59 or 60 Chrysler. But I'm too busy driving.
R.
since you don't care about what I think. I don't think you even have a dodge truck much less a gold engine.
and remember...perception is everything and beauty is in the eye of the beholder when looking at an out of shape run down dodge.
[Re: BulletBob]
#1554730
01/02/14 03:03 AM
01/02/14 03:03 AM
Posts: 1,652 Amarillo, Tx
old_goat
Six Abuser
Six Abuser
Amarillo, Tx
We dont care if ya paint em green! Post up the pics! I post pics of my junk, like this one from a previous engine swap thread...
84 D150 440/727 79 /6 swb D150 1964 A100 window van. Just because it has spark plug tubes doesn't mean it's a Hemi.
If ya haven't been there, ya just wouldn't understand.
