Which HVLP gun?
#155423
11/23/08 07:29 PM
11/23/08 07:29 PM
Posts: 12,076 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I shoot some doors and fenders and do a little blending with base/clear. I have a cheap Harbor Freight HVLP that does a fair job on small pieces like jambs and such. But larger areas takes forever because a wider spray pattern leaves dry streaks at the pattern's edges. A better gun will help here won't it? What gun would you recommend? Especially considering price. Best bang for the buck kind of thing. Thanks!
Master, again and still
Re: Which HVLP gun?
[Re: DaveRS23]
#155424
11/23/08 07:48 PM
11/23/08 07:48 PM
Posts: 7,978 Bethel Ct
AdamR
Bethel Ct
If the pattern is to wide you should be able to adjust it narrower. The painter at my shop does all his cars with a gun that he got in a set of 3 for $80. A expensive gun doesnt make a good painter, LOL
Re: Which HVLP gun?
[Re: DaveRS23]
#155427
11/23/08 08:59 PM
11/23/08 08:59 PM
AdamR
Bethel Ct
Thank you for your observations, but I was hoping experienced painters might respond. The post reflects the fact that I know how to adjust the gun or did the correct spelling and punctuation throw you off? LOL
Gee glad I tried to help you.
Re: Which HVLP gun?
[Re: challengermike]
#155428
11/23/08 09:03 PM
11/23/08 09:03 PM
AdamR
Bethel Ct
Spray a piece of cardboard untill the patteren is where you want it.If its a gravity feed it the knob on the side of the gun,and if its a regular gun with the cup on the bottom its the top knob that faces you.I know there has to be an adjustment on it.I use harbor freight guns all the time and they usually spray great.
Good advise Mike, But hes only looking for help from professional painters with a degree in English.
Re: Which HVLP gun?
[Re: AdamR]
#155429
11/23/08 09:18 PM
11/23/08 09:18 PM
Posts: 28,596 Shopping @ HoBo Fright
340SIX
Doc Flappergas's Evil Twin
I am a 2 time loser then What i read between the lines was he has as a novice reached the limits of what his gun can do! And he wants a better gun to make up for his skills so he can do better work. I know my sharppe planum gun shoots better than my HF purple gun. but i use the purple cheapo for shooting laqure on my cabnets and primer on car stuff to keep the better gun cleaner for paint.
Re: Which HVLP gun?
[Re: AdamR]
#155431
11/23/08 10:14 PM
11/23/08 10:14 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Hey Adam, ever heard of an apostrophe? Anyway, once again, you miss the point. I was just looking for someone who can fundamentably spell and spray. Either way, it's not you.
Re: Which HVLP gun?
[Re: DaveRS23]
#155432
11/23/08 10:22 PM
11/23/08 10:22 PM
AdamR
Bethel Ct
Sure Ive heard of them. Used them once, didnt like it, never used them again.
Good luck with your painting, Hope you can find some one that can help.
Re: Which HVLP gun?
[Re: DaveRS23]
#155433
11/24/08 07:31 AM
11/24/08 07:31 AM
Posts: 2,675 Columbus Ga
reflections7
Columbus Ga
Best bang for the buck is the Divilbiss finishline with the three tips. http://www.autobodytoolmart.com/c-916-devilbiss-paint-guns.aspx
Under cheap guns they sell Astro I want to get the lvlp http://www.autobodytoolmart.com/pc-11608-560-astro-lvlp-gravity-feed-spray-gun-evo4014.aspx Ive heard good things about it. I use a divilbiss hvlp for primers and base coats and a Div plus for clear. Some of the Div gun kits come with 3 tips so you can really do a lot with the one gun.
PS shop around Ive seen them cheaper than the links I sent.
Re: Which HVLP gun?
[Re: reflections7]
#155436
11/25/08 12:10 PM
11/25/08 12:10 PM
Posts: 666 Anywhere the British Secret Se...
Moonraker
Another vote here for Devilbiss not cheap but not bank breaking either and the extra tips to boot, great deal.
Re: Which HVLP gun?
[Re: AdamR]
#155437
11/25/08 12:15 PM
11/25/08 12:15 PM
Moonraker
While I kind of agree thats not always true. Some guns atomize the paint alot better than others and you get a better overall finish and less chance of unwanted blemishes in your paint (i.e. dry spots, tiger stripes, polka dots....). Of course a lot of this depends on the paint to, things like color, metallic vs. nonmetallic and yadda yadda yadda...all play a role.
Re: Which HVLP gun?
[Re: 4BBodies]
#155439
11/25/08 04:12 PM
11/25/08 04:12 PM
Challenger 1
Cincinnati, Ohio
Having been a pro painter, and also being fairly well versed in grammar, I agree with the above advice. For the most part. But a better quality gun does make a difference, why do you think painters willingly pay $400+ for a SATA spray gun? Get the best gun you can afford, the tolerances are better, and they do produce better results. I have always used Devilbis and Sharpe, both companies make decent models in the $200 price range. Just my well spoken .......
Those who say HF guns are ok...have never used a good gun. IMO lol
Re: Which HVLP gun?
[Re: 4BBodies]
#155440
11/25/08 04:21 PM
11/25/08 04:21 PM
I have used most of the guns talked about in this discussion. In my opinion most any gun can be used and get a good paint job. You just have to adjust your gun properly, and have your paint mixed properly.Then you have to be good at laying it on evenly,this is what seperates the wannabe,s from the real painters. And yes i am a proffesional painter,not so good at grammer class though.lol P.S. If you have money to burn get the sata there nice,but you might want to get two, one for base and one for clear.
Re: Which HVLP gun?
[Re: Challenger 1]
#155441
11/25/08 06:09 PM
11/25/08 06:09 PM
Posts: 12,271 Overpriced Housing Central
RobX4406
Who'd shoot $300+/gallon paint with a $30 HF gun??? They shoot primer and surfacer as good as some $200 guns I've used. Which happens to be what the last thread asked about on the CHEAP! Keep it in context.
That Astro Evo gun posted above is a good piece.
Re: Which HVLP gun?
[Re: RobX4406]
#155442
11/25/08 06:17 PM
11/25/08 06:17 PM
Posts: 708 Mechanic Falls, Maine
4BBodies
mopar addict
mopar addict
Exactly. If you are going to spend the money on good paint, you should be willing to pay for a better gun which INSURES a better job. I have owned cheap guns, and yes, some shoot well, some were borderline, and some I wouldn't undercoat with.............I guess some people are luckier than I am. If you bought a good cheap gun and it works, clean the crap of it so it stays working, and consider yourself very lucky. Think of them as any tools, you do get what you pay for..........me, I am eying another Sharpe for my Spring Roadrunner paint job............
Re: Which HVLP gun?
[Re: DaveRS23]
#155445
11/25/08 09:38 PM
11/25/08 09:38 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Pretty good English and pretty good advice. Thanks to one and all!
Re: Which HVLP gun?
[Re: DaveRS23]
#155448
11/26/08 11:33 AM
11/26/08 11:33 AM
Posts: 3,060 Western New York
sixpackbee
Western New York
I use a DeVilbiss GTI Millenium for any job that means something. I have a Binks M1G for collision/spot work. The GTI is a real nice gun and came with three different nozzle sizes. Not real cheap but then again paint is not cheap either. Carpe diem.
1959 Bugeye Sprite 1967 Charger Black L code 1967 Coronet R/T Convert Green 440 auto bought from original owner 1968 Charger R/T Bronze 440 4 spd console AM/FM 1969 Super Bee WM21H B5 A40 D21 N96 1969 Barracuda Formula S 340 Convert pilot car 1969 Hemi Road Runner RM23J D32 Omaha orange 4.10 Dana N96 N85 1970 Super Bee WM23N FE5 V1X 3.91 axle package, N96 1970 Road Runner RM21N B3 V1X D13 1971 MG Midget 1971 Road Runner RM23H GW3, A57 1972 Road Runner RM23P FY1, D21
Re: Which HVLP gun?
[Re: sixpackbee]
#155449
11/26/08 11:42 AM
11/26/08 11:42 AM
I been doin this everyday for the last 14 years and a good gun makes a big difference. I have two SATA digital 2000's and they are the best I have ever used.
Re: Which HVLP gun?
#155450
11/26/08 03:35 PM
11/26/08 03:35 PM
Posts: 2,928 Canada
RobR
Canada
I like using the DeVilbiss guns..I use a GTI or a GFG Plus and a couple of SRI's the SRI-W I find a great little spot gun that can shoot whole panels if I wanted. I'd suggest a GTI the price has come Way down on them and a great gun for the money.IMO I shot this hood with a DeVilbiss 630G spot gun
