Can you mix PPG DPLF primers to get another color?
#155353
11/23/08 05:33 PM
11/23/08 05:33 PM
Posts: 28,611 Shopping @ HoBo Fright
340SIX
Doc Flappergas's Evil Twin
I looked here PPG and don't see it? I would like to mix some of the green DP40LF and DP90LF
Re: Can you mix PPG DPLF primers to get another color?
[Re: 340SIX]
#155354
11/23/08 05:35 PM
11/23/08 05:35 PM
Posts: 4,923 new berlin wisconsin
Mr T2U
yes you can mix different DP colors as long as they have the same catalyst in them.
in my P sheet # P-196 under tinting it says DPLF colors may be blended together. then there is a note under it that says DO NOT BLEND DP AND DPLF together
perception is 90% of reality
[Re: Mr T2U]
#155356
11/23/08 06:43 PM
11/23/08 06:43 PM
340SIX
Thanks I no longer have any DP only the lead free.And i knew that you could not mix the leaded with the new unleaded or mix the 401 and 402, or use the old 401 and 402 with the new LF{lead free} I have half a can of 40lf{green} and wanted to use black from now on. But did not want to mix colors if that was no ok. Wonder what half a can of green{40} and a whole can of black{90} looks like mixed? I have not bought the black yet. FYI I used to use the{40} green since i was told it had more lead than the others. but now they are lead free
[Re: Neil]
#155358
11/23/08 11:19 PM
11/23/08 11:19 PM
Mr T2U
black and green will make a very dark green. i was under the impression from PPG school that green, DP40LF had the highest level of corrosion inhibitors of all of the DP primers.
[Re: Mr T2U]
#155359
11/23/08 11:48 PM
11/23/08 11:48 PM
340SIX
That is what the paint store told me but was only the old DP not the lead free! Now it does not matter
